low coolant light
Re: low coolant light
The sensor has gone bad. Its a common problem. You can either replace it, try to clean it, or simply unplug it. If you unplug it your light will go out and you wont throw any codes.
I unplugged mine! Its located on the passenger side of the radiator, near the battery, below the fill cap.
Jan 23, 2015 01:13 PM
