Low coolant light!!!???
Old Nov 2, 2003 | 01:15 AM
crAzy95z28's Avatar
ok the new car im getting has manual fan switch and he has the sensors on the fans unplugged, so now it shows a LOW coolant light and it wont go away? is that caused by the low coolant light or is that from low coolant!!!if so can i jsut stick a resistor back in there to make it think its connect to the fans?
pleae let me know!!
thansk
randy
Old Nov 2, 2003 | 01:40 AM
DarkRider's Avatar
As far as I know the low coolant light is its own sensor because I had to replace mine(passenger side on radiator about quarter of the way down). I not sure if the fan wiring has anything to do with the coolant level sensor.
If your coolant level is fine I would pull the sensor out and just see if the sensor is caked up - if so just clean it and put it back on .
Let me know if you need me to look at the wiring diagrams
Josh
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
