Low coolant light = Low coolant but no leaks?????
Old Sep 17, 2003 | 11:43 PM
95_RipperZ's Avatar
Where did it go? I checked inside the cap and could not even seen any coolant. Did I blow a head gasket?
I as driving it WOT up a hill and when it shifted into seconds it revved like it was in neautral. I dont know if that has anything to do with anything though.
Old Sep 17, 2003 | 11:46 PM
notstock4long's Avatar
What cap did you look in? The radiator or the resevoir?
Old Sep 17, 2003 | 11:48 PM
95_RipperZ's Avatar
Checked the radiator cap and couldnt see any kind of fluid anywhere. Didn think to chekc the reservoir. I jsut did the cam about 2 months ago and filled it up to the top. I only drive it on weekends.
Old Sep 17, 2003 | 11:51 PM
96speed's Avatar
You should see white smoke in the exhaust if you are losing coolant through a blown head gasket.
Check the resivoir. If its full, your radiator cap is probably not supplying enough pressure. Get a new cap from the store for < $5 .
Hopefully its not a head gasket...
Ryan
Old Sep 17, 2003 | 11:53 PM
Check your other thread for what to do. Try that and let us know what happens.
calaban
May 18, 2020 06:43 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
pologreen97z
Dec 2, 2014 10:42 AM
