Low 13's people.....What you got?
Old Sep 17, 2003 | 04:54 PM
meangreen94z's Avatar
Ok, I am thinking about throwing on a set of Hooker LT's and some 3.73 gears. Mods I have are hooker catback, gutted cat, k&n, ported MAF, TB bypass, new tires (if that counts).
Are low 13's possible? If no, what else should i look into.
Cam, rockers, lifters, head work, etc. may be in the future too. Any help is appreciated.
Old Sep 17, 2003 | 05:04 PM
RamAir95TA's Avatar
See sig.
Old Sep 17, 2003 | 05:31 PM
KCFormula's Avatar
I went 13.4@104 with a 2.17 60'. With a better launch I could hit a lower 13.
Mods in sig
Old Sep 17, 2003 | 05:44 PM
FastZinTennessee's Avatar
I hit 13.5 @103.7 with a K&N intake, meziere waterpump, SLP headers, off road pipe and flowmaster catback. I could have done low 13s with a good stall converter at that point.
John
Old Sep 17, 2003 | 06:21 PM
chevy94c's Avatar
My car does very low 13's maybe high 12 with good traction. Without nitrous
Old Sep 17, 2003 | 06:45 PM
94formulabz's Avatar
Here is my progression.
Only thing not on there is since my cam i went 3x 13.0x@ 111.x at beaver springs, a slow track. Picked up 5mph but only 2 tenths. Couldn't get the car to hook. There is definitly a lot more potential there when i go back to maple grove.
Old Sep 17, 2003 | 07:15 PM
Fastbird93's Avatar
I went 13.09@106.82 with ASM headers, Random Tech Cat and Cat Back, Nitto DR's, OEM Ram Air equipment, hypertech powercoil, pcmforless tuning, 160* tstat, and a B&M ripper.
Old Sep 22, 2003 | 03:06 AM
Dragon Racing's Avatar
See sig.
Old Sep 22, 2003 | 08:33 AM
93RAM-AIR-BIRD's Avatar
My car has 3.73's, a hi-stall torque converter, Shorties w/SLP cat back, K&N w/ factory Ram Air, aluminum drive shaft, Transgo shift kit w/corvette servo, throttle body bypass & 160 thermostat. I run on Nitto DR's and run 13.3's @101mph or 102mph consistantly. I would run faster except I can't get off the line hard. My best 60 ft is 1.8 and I launch just barely over an idle. If I could stand on it a little harder I am sure that high 12's are within reach. My car was in the GMHTP LT-1 shootout with the previous owner. He did run a 12.9 @ 104.88, but didn't run that well in the shootout. I think he had the air pump off, sway bar out, and a gutted cat. He made the car legal before he sold it. It still runs great. Keep at it you will get there.
Old Sep 22, 2003 | 08:58 AM
curly's Avatar
13.57 with borla y-pipe / morflo cat, 3:23's, K&N FIPK, and weld-in flowmaster muffler. I want 12's..............
Old Sep 22, 2003 | 08:59 AM
95TA8280's Avatar
Re: Low 13's people.....What you got?
With everything you listed in there (heads/cam) you could be low 12s....
Low 13s? Get some suspension too, you can't forget about that. 13s are a lot easier with a 2.0 60' than with a 3.0 60'
Old Sep 22, 2003 | 09:48 AM
1Z2Z's Avatar
13.57 @104 w/ 1.97 60'
Stock engine (94 LT1) w/ CAI and FLP LTs (open). M6, 4.10s. Spohn rear suspension and TA, Prokit. Prostars, ET Drags and skinnies.
Fear of scattering my 10 bolt holding me back from harder launches, shifter is balky on 2-3, and I need more practice. Mike
Old Sep 22, 2003 | 10:07 AM
Sweetred95ta's Avatar
Went 13.35 @ 104 with just most bolt ons. K&N cai, GMS MAF, Air-foil, 160* stat, custom programming, 3.73's. Through stock manifolds, stock cat, stock converter, running 2.0 60 ft. times. I think custom programming helps the most (it brings out all the potential of all your mods). With a 3200 vig, I could have went 12.70's probably.
Benji
Old Sep 22, 2003 | 10:55 AM
ROADRAGE's Avatar
I went 13.4 with a K&N, 3:73's and a Vig 2800 and 245 BFG's
Had 110,000 miles on the completly stock motor.
Old Sep 22, 2003 | 11:33 AM
ksmyss's Avatar
time in sig was with slp headers, true duals, accel 300+, mad wolf OBDI conversion, under drive crank pulley, LCAs and brackets, 4.10 gears and drag radials
