loud ticking
Old Jun 28, 2007 | 07:52 AM
dangalla's Avatar
loud ticking
went into resteraunt last night for a couple drinks and came out like 2 hours later, started car and immidiately there was a loud ticking noise(knocking). still has good oil pressure and normal power, not overheating. almost sounds like a collapsed lifter or something
my question is what is the possibility of a lifter collapsing while eating dinner like that, when i get out of work today i am going to pull the valve covers to check for loose rockers
Old Jun 28, 2007 | 09:18 AM
BassProCamaro97's Avatar
Doon't over look your spark plugs being loose. I just redid my wires and found that some of my plugs had worked loose creating that irritating tapping noise. Gave my plugs a good tightening and no more noise.
~Jim~
Old Jun 28, 2007 | 09:38 AM
GaJoe's Avatar
not sure if you have headers or modified exhause...heck even stock exhause check to see it maybe there is an exhaust leak...
Old Jun 28, 2007 | 10:00 AM
dangalla's Avatar
na this is def in the motor sounds like either a wrist pin(god i hope not) or a collapsed lifter which is what im hoping for. only mods are magnaflow cat back, now that i think about it, it could be a bent pushrod i guess. happened late last night so i did not get a chance to look at it yet
Old Jun 28, 2007 | 10:37 AM
96LT1TX's Avatar
when my wrist pin came loose it sounded like a chatter (on deceleration only). A tap would be valvetrain if you ask me, like you said a lifter or a bent pushrod. I dont see how either of those could have happened while you where at the restaurant, doesnt make sense. I would check under the valvecovers. If you have stock valvetrain that is strange though, did you drive it hard right before this happened?
Old Jun 28, 2007 | 11:27 AM
dangalla's Avatar
no not at all it was raining really hard so i was just cruizin nice and slow, it seems really odd to me that this happened on start up like that, and yeah when i get home im gonna pull the valve covers and see if anything is loose, at work right now
Old Jun 29, 2007 | 01:23 PM
Explodinggopher's Avatar
This also happened with my cammed 5.0 fox mustang, after cruising to someones house and then started it up about a few hours later, I had a collapsed lifter. So it is possible. I used that to warrant my 460 big block swap lol.
Old Jun 29, 2007 | 01:51 PM
LTgun_94's Avatar
Could be bent pushrods. One of my friends had a ticking sound that sounded like an exhaust leak that kept getting louder and louder, someone recommended him to take a look at his pushrods and sure enough about six were bent. They were bent marginally, or to a great degree but enough to make the sound. He changed them and the ticking went away.
Old Jun 29, 2007 | 05:46 PM
dangalla's Avatar
yup, internal somewhere, oh well no car for a couple weeks, then a built 355 after that.....
bringin it to work mon to pull the motor
hope it doesnt mind being in a ford dealership
RUENUF
Mar 13, 2016 03:37 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
1slow93z28
Sep 1, 2015 06:22 PM
Latronaxe
Jul 17, 2015 11:55 AM
Nick's WS6
Aug 20, 2002 10:34 AM
