Loud sounds from rear......not gas!
Old Jul 11, 2003 | 08:27 PM
Craig@HFP's Avatar
I just changed my stock '95 long as*ed 2.73 rear-end over to a complete rotor to rotor LS1 rear with 3.42's. Everything went OK as all the parts lined up.
Now the only problem I have is the increadible noise from the rear! I dumped the goo out of the LS1 dif. and filled it with Mobil 1 synth. (I already know this was a mistake ) I later added the GM additive hoping to see SOME improvement before switching to castrol and GM additive. Still lots of deafening noise at highway speeds.
My questions are:
A: Did I screw this up by running Mobil synthetic?
B: Should the rear make the rumbling/slushing noise when using synthetics?
C: Other than clutches/cones slipping with sythetic, will the swap to dinosaur oil really change the volume and expensive noises coming from the rear end?
D: Have I hosed myself with the rear end swap?
Thanks in advance for any help or advice.
Craig
jackpawt883
May 26, 2015 12:13 AM
May 15, 2015 10:43 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
squarehead
Nov 21, 2014 08:02 PM
