lots of help needed please!!!!
Old Sep 22, 2003 | 12:45 AM
97BLKZ28's Avatar
im having some serious issues with the car. its throwing these codes
po174
po336
p1641
p1642
po161
when i try and start the car, i have to prime it like 6 times, and i have to stomp on the gas to get it started, then when it starts it runs fine for like 20 minutes, then it starts chuggin when i hit the gas, throttle response gets bad and there is about as much power as a v6 mustang. then when i drive it and stop somewhere and shut it off, it wont start unless i let it cool for like 2 hours, i am completely lots and would love some help.
could and problems be from my new holley 155lph fuel pump?
i cant handle dring my jeep around anymore please help
thank you.
Old Sep 22, 2003 | 01:00 AM
Spinner's Avatar
po174 - Fuel Trim too Lean (Bank 2)
po336 - Crankshaft Position Sensor A Circuit Range/Performance out of spec
p1641 - Fuel Pump Primary Circuit Failure
p1642 - Fuel Pump Monitor Circuit High Input
po161 - O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
Your fuel pump can't keep up. Why you installed a 155 lph is beyond me anyway. The problem seems to be fuel pressure though, get a fuel pressure regulator. Also make sure the pump is installed correctly. Replace the bad O2 sensor and crank sensor, and you should be good to go.
Old Sep 22, 2003 | 01:12 AM
97BLKZ28's Avatar
i thought the fuel pump was an upgrade
Old Sep 22, 2003 | 01:15 AM
Spinner's Avatar
The stock pump can flow 155 lph AFAIK. Either way, I think you somehow messed up your installation. Your motor isn't getting enough fuel, which begs the need for an adjustable regulator
Old Sep 22, 2003 | 01:17 AM
97BLKZ28's Avatar
is there a fuel pump relay or something that could have gone bad or something?
Old Sep 22, 2003 | 01:19 AM
Spinner's Avatar
Old Sep 22, 2003 | 01:32 AM
97BLKZ28's Avatar
i just replaced the crank sensor, i think that one is showing because of the cam i put in it, has anyone else had this problem with the cc-305 cam?
Old Sep 22, 2003 | 09:01 AM
97BLKZ28's Avatar
what would cause
bad pump, does it have a relay?
Old Sep 22, 2003 | 10:49 AM
Don't know where that info about fuel pump is coming from, but the codes are for the fans:
P1641 Fan Control (FC) relay 1 control circuit
P1642 Fan Control (FC) relay 2 and 3 control circuit
If you have a manual fan switch that is not wired in with some extra resistors, it can cause those codes.
Old Sep 22, 2003 | 01:34 PM
97BLKZ28's Avatar
can o2 sensors cause that many driveablity issues and stating issues?
Old Sep 22, 2003 | 03:38 PM
97BLKZ28's Avatar
and there is also no pressure in my gas tank
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
