Lost a rr nut
Old Oct 3, 2004 | 11:06 AM
Wildwill2855's Avatar
Lost a rr nut
Lost one today, what can i use in place of one, are they required or no. i called shops they were all in a set of 16 and thats not what im needing.
Old Oct 3, 2004 | 01:00 PM
Mtrhds94Z's Avatar
Re: Lost a rr nut
Well yes it's required since it holds the RR on and you adjust them with it..
Not sure what you could use in place of one except another one.. you MIGHT get by with a stock rocker nut for a few days?
Old Oct 3, 2004 | 03:37 PM
Spinner's Avatar
Re: Lost a rr nut
If its a stock nut, I can snail mail you one in the morning. LMK. As far as i know though, polylocks (roller rockers) are only sold in sets of 8 or 16
Old Oct 3, 2004 | 03:39 PM
brandboZ28's Avatar
Re: Lost a rr nut
Which rockers are you using? I have the CC 1.6 ProMags and ended up having to replace one. Depending on how much a set of 16 nuts are, it might be cheaper to just buy another rocker and nut and have a spare rocker laying around just incase. It was about $25 plus shipping if I remember correctly. Like Mtrhds94Z said, you might be able to get away with using a stock nut for a little while but I would use it long.
Old Oct 3, 2004 | 05:27 PM
Re: Lost a rr nut
i meannt i have stock 1.5 rr from the factory and lost one? I dont have any HP RR yet
Old Oct 3, 2004 | 06:15 PM
Mtrhds94Z's Avatar
Re: Lost a rr nut
Do you mean that you have stock 1.5 stamped steel rockers?
Or do you have an LT4 with stock roller rockers?[RR means 'roller rockers'?]
If it's a stock nut you need, I'd take Spinner up on his offer there..
Old Oct 4, 2004 | 03:39 PM
Re: Lost a rr nut
Stock LT1 with factory stamped arms.
Old Oct 4, 2004 | 03:42 PM
n2ceptor's Avatar
Re: Lost a rr nut
At Carquest you can buy a single nut.... At least here they do.....
Old Oct 4, 2004 | 03:43 PM
Mtrhds94Z's Avatar
Re: Lost a rr nut
I'd ask Spinner to mail you one [or 2!]then.. he offered to..
Old Oct 4, 2004 | 07:36 PM
Re: Lost a rr nut
Im not sure what size a spark plug socket is thats what size fits the nuts, would a nut off a E7 Ford head, rocker arm work im thinkin their the same size?
Old Oct 4, 2004 | 09:21 PM
n2ceptor's Avatar
Re: Lost a rr nut
5/8ths......
blac94Z
Nov 4, 2015 01:59 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
tdigger9899
Sep 7, 2015 10:56 AM
