Losing coolant
Old Apr 25, 2005 | 10:08 AM
Kuma's Avatar
Losing coolant
Hey guys,
My engine seems to be losing coolant at an alarming rate. Most recent mod was a set of jet-hot long tubes. Note that there is no coolant on the ground, ever--it just seems to vanish...I know that probably doesn't sound good. Also, it seems to be using oil (I use Amsoil or Mobil 1) which it never did before.
I fill the coolant and a week later the low coolant light goes off...
Thanks in advance.
Old Apr 25, 2005 | 10:29 AM
DugRat's Avatar
Re: Losing coolant
Do a compression test or pressure test your cooling system, I bet you will be doing headgaskets.
Old Apr 25, 2005 | 11:07 AM
Kuma's Avatar
Re: Losing coolant
Oh man. Alright. Thanks for the advice...it would make sense...
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
