Lose power at higher RPM's
Old Nov 28, 2020 | 11:13 AM
mrmint69's Avatar
I have a super charger and it drives perfect unless I floor it. It's like the engine cuts out for a second. As soon as I let off the gas it's back to normal. It has boost and around 1 1/2 to 2 lbs is where it has problems. Stock engine for the most part. Super charger installed 17 years ago with zero problems till now.
Old Nov 29, 2020 | 02:44 PM
mrmint69's Avatar
Re: Lose power at higher RPM's
I started by checked the battery and found the positive was loose. After tightening it up the problem went away. Maybe this will help others who have something similar happen.
jst
Oct 23, 2005 10:02 AM
detroit1994z28
Dec 10, 2004 05:49 PM
JSK333
Advanced Tech
35
Oct 19, 2003 03:06 PM
WannaBeZ28
Jul 10, 2003 01:46 PM
