Loose steering?
Old Feb 9, 2005 | 09:49 PM
madwolf's Avatar
Loose steering?
My car is in storage, but I took it for a ride the other day and my steering felt kind of "too easy". My other Z was different from what I can remember.
I replaced pretty much all the suspension on this car including new balljoints (one tie rod does seem to need replacement though, the other is new) and LS1 brakes. Is there anything I can do to stiffen it a bit?
Could the fact that I have 275 tires on the front have anything to do with it? The car seems to chase a lot on the road too.
Thanks.
Old Feb 9, 2005 | 09:52 PM
sw89lt1's Avatar
Re: Loose steering?
sounds like tierods are shot.
Old Feb 9, 2005 | 09:57 PM
neil350's Avatar
Re: Loose steering?
Yea, tierods have worn out, mines has gotten worse with age as well. Alls cars do that at some point
Old Feb 9, 2005 | 10:00 PM
madwolf's Avatar
Re: Loose steering?
Can I replace them myself or do I need special tools for that? (I know they come out on the brake knuckle side easy, but what about the other side?)
Of course, I will be taking it to a shop for an alignment afterwards.
Thanks.
Old Feb 9, 2005 | 10:08 PM
neil350's Avatar
Re: Loose steering?
I'm sure they can be replaced your self, never done the job butI know a lot of people have. Just like shocks they are a wear out item, I saw on Horse Power TV years ago that baer made some replacment ones but not sure any more.
Old Feb 9, 2005 | 10:10 PM
madhatter's Avatar
Re: Loose steering?
You can also get a ragjoint eliminator. I have been meaning to get one for awhile now...
Old Feb 9, 2005 | 10:14 PM
sw89lt1's Avatar
Re: Loose steering?
it is very easy simple handtools, just put a dab of spray paint on the threads to mark how far u screw the new ones on. i use moog parts.
Old Feb 9, 2005 | 10:38 PM
Re: Loose steering?
Tie rod ends are not hard. As already suggested, measure the length of the old ones and make the new ones the same. Then have your alignment checked. I noticed a little improvement in rut tracking when I replaced mine, but the wider the tire, the worse the rut tracking is. Air pressure is a factor in that, too.
Old Feb 9, 2005 | 11:59 PM
redcamaroz28's Avatar
Re: Loose steering?
Even if it's not a problem, I'd get the rag join eliminator. It makes a huge difference in the tightness of the steering. Here is the site:http://www.unbalancedengineering.com/Camaro/.
Old Feb 10, 2005 | 12:02 AM
madwolf's Avatar
Re: Loose steering?
Thanks for the advice!
I'll probably get one of these.
Anyone know where is a good place to get Moog tie rod ends?
Old Feb 10, 2005 | 12:11 AM
madwolf's Avatar
Re: Loose steering?
Oh yes, forgot to ask. Do I need to replace the ends only or the whole thing?
HibachiZ28
Nov 6, 2015 12:53 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
