Loose Spark Plugs
Old Feb 6, 2007 | 05:23 PM
diamondhill's Avatar
Question Loose Spark Plugs
I had a ticking noise from my engine and i thought i was a lifter ,but it turned out to be that my spark plugs were loose, besides causing ticking noises what other bad things could have happend from my spark plugs bieng loose? could any engine damage have occured? it seems to be running great, and all my spark plugs were a about a full turn loose
Old Feb 6, 2007 | 05:24 PM
reamo04's Avatar
same thing happens to me, i have to tighten my plugs about once a month
Old Feb 6, 2007 | 05:26 PM
2000GTP's Avatar
There may have been some lost power due to a loss of compression, but I doubt you did any serious damage. Tighten them up and see how it runs.
Old Feb 6, 2007 | 05:27 PM
SS Joe's Avatar
Its doubtful it hurt anything. I don't think the plugs loosen up so much, but a lot of tools people use don't fit down in the tight recess around an LT1's plugs. They may feel tight with one tool, but use a thinner wall socket and you can usually get them a little tighter.
Old Feb 6, 2007 | 06:17 PM
95LT1conv's Avatar
if its not taken care of soon though, the plugs CAN tear the threads out of the head. Ask me how i know
Old Feb 6, 2007 | 07:10 PM
well i tightened them up and everything seems ok. i guess ill have to check them out once a month
Old Feb 6, 2007 | 07:24 PM
JP95ZM6's Avatar
I never have the plugs come loose. I suspect you guys are not getting them tight like SSJoe said. Take some time to find a tool that works. I have a bent wrench for some plugs. Note most plug sockets have wrench flats on them that can help. Those cheap sheet metal plug wrenches like you get with snowmobiles, dirt bikes, etc are real thin and can be turned with a wrench or a screwdriver stuck through the holes, too. About $2 and can be cut to required length, then drill new holes where you need them. Like this:
http://www.hardwareworld.com/Spark-P...h-pRNHCXO.aspx
Old Feb 7, 2007 | 12:49 AM
revtime's Avatar
I use a lot of anti sieze. I usually have to retighten 3 or 4 plugs to get them to stay tight when I install a new set.
Don't want to tighten them too much and strip the threads.
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
