Loose Spark Plugs
I had a ticking noise from my engine and i thought i was a lifter ,but it turned out to be that my spark plugs were loose, besides causing ticking noises what other bad things could have happend from my spark plugs bieng loose? could any engine damage have occured? it seems to be running great, and all my spark plugs were a about a full turn loose
Its doubtful it hurt anything. I don't think the plugs loosen up so much, but a lot of tools people use don't fit down in the tight recess around an LT1's plugs. They may feel tight with one tool, but use a thinner wall socket and you can usually get them a little tighter.
I never have the plugs come loose. I suspect you guys are not getting them tight like SSJoe said. Take some time to find a tool that works. I have a bent wrench for some plugs. Note most plug sockets have wrench flats on them that can help. Those cheap sheet metal plug wrenches like you get with snowmobiles, dirt bikes, etc are real thin and can be turned with a wrench or a screwdriver stuck through the holes, too. About $2 and can be cut to required length, then drill new holes where you need them. Like this:
http://www.hardwareworld.com/Spark-P...h-pRNHCXO.aspx
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
