Loose Harmonic Balancer? help please...
Old Apr 24, 2007 | 05:25 AM
  #16
cnorton's Avatar
Carefully examine the ATI unit. It is a two piece assembly. If only the hub is damaged it shouldn't be necessary to replace the entire assembly. Conversely, if the outer ring is the problem you might salvage the hub. The ring will only fit on the hub one way and the eccentric hole is clearly marked so that when all the bolt holes are aligned, the ring will be be back in the original position. The opti can be swapped by removing the outer ring and sliding the distributor around the hub. If the torx countersunk cap screws that hold the outer ring weren't torqued correctly or if some of them were left out, the ring unit could be loose on the hub.
It goes without saying that having the correct key in the crank is essential.
Old Apr 24, 2007 | 10:06 AM
  #17
lifbcracker's Avatar
ah so its the out ring and the hub that make up the whole ATI damper? if thats the case then i am actualy able to move the whole assembly up, left and right almost a 1/4 inch
Old Apr 24, 2007 | 11:38 AM
  #18
blown383's Avatar
Originally Posted by lifbcracker
sorry to all, i have a golen 383 - steel crank, forged i beam rods, srp pistions, ported lt1 heads - the list is endless. its all N/A no boost.
i am running the ati superdamper (i still thought it was called a balancer as well) - it was installed all up at golen with the damper balanced on the engine dyno. I then imagin it was taken off for the MSD opti install and the new valves for the heads.
The damper should not have been balanced on along with the rotating assembly. The balancer is neutral balanced.
-B
Old Apr 24, 2007 | 12:56 PM
  #19
well however it is done it was done the correct way
Old Apr 25, 2007 | 04:07 PM
  #20
thanks for all the replies, has anyone else had any problems with there Golen engines?
Old Apr 25, 2007 | 04:30 PM
  #21
Guest47904's Avatar
Guest
What are you talking about. A problem with the engine. Don't you think the ixxxt that took it off to get to the opti did something????????
I just recently had the valves redone at NLP and they did take off the timing cover to put of the MSD
Incidentally you don't have to take the timing cover off to replace the opti.
More than likely you have a failure with the damper.
Jeff1904
Jun 5, 2016 05:00 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
