looking to get a throttle body
Old Sep 26, 2005 | 01:26 PM
SinisterSix's Avatar
do you think this is a good deal?
http://cgi.ebay.com/ebaymotors/1993-...02027298QQrdZ1
or should i with a 58mm?
Old Sep 26, 2005 | 01:40 PM
95patriotZ's Avatar
Re: looking to get a throttle body
At first glance it looks fine. Good price I guess. What are your mods?, because a throttle body that is too big for your current mods will infact hurt performance, just something to think about. Overall if you need a throttlebody I would try it
Old Sep 26, 2005 | 01:47 PM
so far i've done K&N CAI ,shft kit 2400 stall i'll be doing gears (3.73) and cat back this month..
Old Sep 26, 2005 | 01:51 PM
Black_Z28's Avatar
Your stock TB will be fine with the mods you have. You really don't need a aftermarket one until you're in the 400HP area. Then you might benifit from a 52mm TB. I still have a stock TB and I have pretty much every bolt-on and heads/cam.
Old Sep 26, 2005 | 03:39 PM
2000GTP's Avatar
Very much agree, save your two hundred bucks for something else.
Old Sep 26, 2005 | 04:07 PM
Z95m6's Avatar
I'd spend the money somewhere else. I'm not sure if a bigger TB really helps until you get some major horsepower. I'm not exactly sure my 58mm tb was worth the money.
Old Sep 26, 2005 | 05:59 PM
80TA's Avatar
I have seen dyno tests of some hp gains with 52 and 58 tbs even on mildly modded up cars. So it appears that they can help a bit .Sometimes theory and practice are two different things.
The car is already set up for a 52 but you need to bore out intake for a 58 or buy an adapter,seen those on eb. I just got a 52 but might go for a 58 when finish heads/cam/ and headers. Have zex wet kit also.
Old Sep 26, 2005 | 07:36 PM
95patriotZ's Avatar
Any actual numbers? I couldn't imagine it putting down enough real HP gains to justify getting a larger throttle body. Yeah, sure it may put down 5 extra hp, but 5 hp for about 200 dollars isn't a very good investment, at least in this stage of the modding game. You could spend it on something else more benficial (SP?).
Old Sep 26, 2005 | 08:27 PM
Z95m6's Avatar
I wouldn't waste my time on the adapter it will still choke you down to 52mm.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
