Looking for comments on my future setup...
Old Jun 25, 2004 | 07:47 PM
  #16
a5150ward's Avatar
Great advice BUBBA
Old Jun 29, 2004 | 02:08 PM
  #17
MTL_Z28's Avatar
Originally posted by BUBBA
OK: You've apparently already decided to go with a relatively large cam so bearing in mind that your engine is just an air pump, the better it breaths the more power you make.
On the intake, a 48MM is big enough. On the exhaust, go with LTs. Don't waste money on larger TBs or bigger injectors when you are trying to save some money.
Put ALL you savings in having your heads done. Lt1 heads can be very effective with a good Port and pocket job. Throw in a polish and even better.
As far as timing chain, if you need to change it out anyway, might as well do it right (I will let someone else advise you on the T Chain).
Seems like you have enough $$, esp when you are talking about suspension, etc., but I'd make sure those heads are done RIGHT.
If anything as far as suspension, SFCs, etc., I'd opt for a 12 bolt rear, if it was a toss up.
If you can't put it to the ground without breaking things, you are missing the best. JMHO
For the throttle body I will be getting a stock ported 52 mm throttle body since I found someone who does it for relatively cheap (169$) If my car was stock I wouldn't waste money on it, but with ported heads and a cam, chances ar the ported TB will help a little bit. Also I found a set of 28# LT4 fuel injectors in the FS section.
I already have hooker long tubes and a mufflex Y-pipe, although I may decide to sell the y-pipe and go for a true dual setup.
You're right about the heads, I'm not going to skimp out on them, I found a local porter here that does great quality work. ALthough my porter has recommended that I ditch my off the shelf cam and go with a custom cam from www.cammotion.com instead after I get my flow numbers to get a cam that best matches my needs. He's probably right, but I'll see what I am going to do about that.
Old Jul 10, 2004 | 02:44 PM
  #18
MTL_Z28's Avatar
Originally posted by LT4POWR
use the impala gaskets...more bang, less buck
Are there any drawbacks to using the impala gaskets? Like for example would it be easier to blow a headgasket since they're thinner?
Old Jul 13, 2004 | 01:22 AM
  #19
MTL_Z28's Avatar
Also do you think a set of clevite 77 bearings is a good idea? I hear a lot of people the do head/cam swaps that end up with spun main or rod bearingsand I was wondering if a set of new bearings would be a worthwhile investment?
Old Jul 13, 2004 | 12:19 PM
  #20
94Zpower's Avatar
The custom Cam that works with the flow #s from your heads will be the most affective.
its like a tailor made suit, its made to fit u not every one else at the store
Old Jul 17, 2004 | 12:13 AM
  #21
MTL_Z28's Avatar
The adventure begins this monday...
I'm a bit nervous
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
TGGodfrey
Aug 18, 2015 06:08 PM
