Looking for a cheap LT1 build, any ideas?
Old May 12, 2010 | 05:17 PM
charliediss's Avatar
Block just got cleared at the machine shop, have an after market set of heads, but everything else is currently unknown. I am not necessarily trying to build power here, just looking for a stock build but will probably have to go .30 over on the block. Who has decently valued rebuild kits? How much should I expect to pay for the machine work? What is a decent cam for a stock engine? Any input would be greatly appreciated!
Thanks!
Charlie
Old May 12, 2010 | 07:50 PM
MachinistOne's Avatar
Your machine shop should be able to answer those questions and supply the parts at a decent price for a stockish rebuild. Replacement speed-pro or mahle hyper pistons, mild 220 something duration cam.
What heads do you have, that seems like a lot of expense for a stock motor and basically a waste of potential power...
Old May 12, 2010 | 08:52 PM
Well let me give you some backround first... I built a 396 for MY car and purchased the trick flow gen x 23* heads off summit. Upon further research, I realized that a set of LE2s would better benefit my application and decided to sell the TFs to my buddy who is doing a stock build. What do you think? Also, my machinist is charging my buddy 860 for the machine work and another 400 for assembly...that seems a bit high? Or is that on par? Hey I really appreciate the input here, my buddy is in Afghanistan right now, and I don't want to do him wrong here, it stinks over there!
Thanks again
Old May 13, 2010 | 12:31 PM
Slick-Z's Avatar
Thats a good price but really prices vary for the lt1 on which state your in. Some states have lots of shops that specialize in lt1. I found that carolina machine engines will do a short block rebuild for eight hundred dollars which is a steal and and long block for sixteen hundred and thats the best prices ive found on line in the past year so your doing fine. I have not found a shop in oklahoma that will do a short block for an lt1 under sixteen hundred dollars and a longblock for about twenty three hundred. Well i just decided to do it myself. So yeah i would say thats a pretty good deal especially due to the fact that its not a stock rebuild because usually as soon as you tell them that its not exactly a stock replacement they say well let me switch you over to the performance side of the shop and the price just goes up. Good luck man
Old May 13, 2010 | 03:26 PM
slomarao's Avatar
what is your budget and goal?
Old May 13, 2010 | 05:13 PM
Well my budget is 1000 maybe a little more...seeing as I already have a set of decent heads for it and my goal is stock+20...maybe. I am not really looking for huge gains, I just want something that will be reliable and still stout enough to make people think.
hey, thanks for all the input guys!
Charlie
Old May 13, 2010 | 06:16 PM
RamAir95TA's Avatar
Your budget is very slim to do anything other than a VERY budget stock rebuild using all stock parts. A cam and its supporting mods will run you about that much already. You're looking at about 2k to do it right, maybe more.
Old May 13, 2010 | 10:22 PM
Yea I suppose you are right. I just went to the machinist and am working a build that will be in the ball park of 2000ish...including new timing hardware, cam, etc. Should I still go with those trickflow heads on a stock engine?
Old May 13, 2010 | 10:40 PM
dangalla's Avatar
i would use ported stockers, i thought you have le2s and gave the TF to your buddy
stock crank is fine, just use a good i beam and stock style hyper. pistons. stock timing hardware, arp head bolts and main studs.
Old May 14, 2010 | 10:51 AM
I have not bought my set yet, need to free up the cash from the TFs before I pick up the LEs. Man, I am just all turned around right now, I need direction...Since I have discretion over a a couple grand for my buddy, I do not want to make the wrong decisions ya know? Will running the TFs on the stock bottom end work backwards? Should I even do that for him or should I just get his stockers reworked? Man I am confused!
Old May 14, 2010 | 11:04 AM
RamAir95TA's Avatar
The TFs will lower your compression as-cast, so I would advise in using ported stock castings. They will deliver what you want (either from AI or LE, although I used AI...LE seems to be having some issues problems lately).
Old May 14, 2010 | 04:20 PM
Thanks for the advice! I have settled on a stock rebuild all the way down to the heads. He is charging me 2300 for a COMPLETE rebuild and assembly...what do you think?
Old May 28, 2010 | 09:24 PM
97ramairta's Avatar
just have the trick flows milled down some and use the b-body head gaskets and you wont have any problems with compression being low. the trick flows will be ok on a stock bottom end with a cam. wont hurt anything at all you just wont be using the full potential of the trick flows.
Old May 29, 2010 | 12:48 PM
Dtimekw's Avatar
Charlie, I think most of us who have built our motors know we will go over budget but also have a HP goal to reach. A stocker is great BUT since you are already in the motor, why not put a mild cam in and do a little head work? You can built decent power with H/C combo on a stocker bottom end. Did you have a particular HP you wanted to go with or just a reliable DD? Either way, there are people on here who will help you out, they know thier stuff without a doubt.
BTW - Hats off to your buddy and anyone who goes out that way. I've sent a couple of my guys over to the sandbox already and glad to see them when they get back.
Moshbmx1
Jan 20, 2015 03:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jrlt1
Jan 3, 2015 07:38 PM
