Looken for a 500+HP recipe 4 a lt1.
Old Nov 30, 2008 | 12:32 PM
1slo93z's Avatar
I have a 93 z28 that needs 2 go as fast as it looks! I would like 2 keep the stock heads and intake just opened them up.I have a 150 shot of nos.My budget is 4 grand.Thinken about going 383. I dont know what size cam,valves or converter 2 go with. I definately want a whoomp ta dee whoomp sounden car! Interested 2 see what you all have 2 say.
Old Nov 30, 2008 | 01:52 PM
CrashnBurn's Avatar
my set up is around 440 rwhp without nos so there you go and you could get more with a custom grind cam. DO A LOT OF RESEARCH BEFORE YOU START. It'll save a ton of headaches, time and money. Ohhh and i do NOT suggest going with a fuddle converter(good product, HORRIBLE customer service.)
Old Nov 30, 2008 | 02:28 PM
Javier97Z28's Avatar
Moderator
Increase your budget or forget the goal.. numberwise.
The stock transmission and rear end will not hold.
Old Nov 30, 2008 | 04:08 PM
526 SS 96's Avatar
I don't think you can do it for four grand, but I do have a combination that is exactly what you are asking for. See my sig
Old Nov 30, 2008 | 05:52 PM
seawolf06's Avatar
Fast, reliable or cheap. You can only pick two!
It can be done, but you're probably going to need more than 4 grand to make it.
Old Nov 30, 2008 | 05:53 PM
LSWHO's Avatar
Buy a used LS1 with heads/cam already on it and do a swap. You might make 500hp.
Otherwise with an LT1 you aren't making 500 whp cheap
Old Nov 30, 2008 | 06:37 PM
96m6lt1's Avatar
4 grand does not go very far on an Lt1
block work,bore, stud, align hone,4340steel crank,good rods,forged pistons w/rings,nice solid roller,sr lifters,double roller chain, i think i past the 4k mark and you still need heads,roller rockers,header,exhaust,58mm,trans/stall or clutch assembly,fuel system,TUNE,12 bolt or s60,TQ arm,SFC yeah!!!!!!! 4k won't get you too far on this list of missing items...
why is 500hp your magical number?
why not do weight red. all suspension mods and a rear end that won't break as easy and some tire and nitrous,now that would be an awesome street car!
Old Nov 30, 2008 | 07:10 PM
slomarao's Avatar
you have not really told enough info to get good answers. Are you talking about flywheel or rearwheel hp? They are two very different things, and with a stalled auto even more so.
with 4k you could maybe build a mild 383 assuming you can do every last bit of labor. Than you would have fuel system, tuning, suspension, and a rear end to save another 4k for. Again assuming you did all labor, if not add 35%. Than 750-1000 more for a decent n2o kit with safety items.
There is a saying around here that has already been mentioned. Fast reliable cheap, you pick two. Think about it.
truecontr3
Oct 11, 2015 09:30 AM
Beave2780
Sep 23, 2015 12:37 PM
350350
14
Aug 11, 2015 12:03 PM
cmsmith
Apr 11, 2015 09:37 PM
stallone
Apr 26, 2002 10:00 AM
