Longtubes hitting floor.. knock???
Old Nov 30, 2006 | 02:22 AM
  #16
ZBLKHELLRZR's Avatar
93's may not have a knock sensor but I know when my y-pipe use to hit the floor board timing was pulled at least 7-10 degree's. I put solid mounts on after that and that issue was resolved.
Old Nov 30, 2006 | 03:34 AM
  #17
SS RRR's Avatar
Originally Posted by lt1 kenobi
Ok I've tried to adjust the y pipe and such every which way and no matter what.. sometimes when I get on it they will vibrate against the floor... My question is... will this cause my knock module to sense knock and pull timing ?? I've heard of it happening but I want to know if it is a regular occurance. thanks in advance
Do you have any idea where the exhaust is hitting? Most popular area is the tranny cross brace on the drivers side. There is a raised section on the brace which interferes w/ a y-pipe. The raised portion can be taken off with a grinder and usually solves the problem.
Old Nov 30, 2006 | 07:22 AM
  #18
Sweetred95ta's Avatar
Originally Posted by ZBLKHELLRZR
93's may not have a knock sensor...
93's do have a knock sensor.
That's what I did and I haven't had a problem since.
97SSdude
Aug 21, 2015 09:36 AM
whitehooptie
Aug 10, 2015 07:02 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
jbc3
Jul 28, 2015 12:24 PM
