Longtubes finally out the back
Old Oct 16, 2004 | 05:36 PM
  #16
PatriotTA's Avatar
Re: Longtubes finally out the back
Originally Posted by 95Zdroptop
Would removing the panhard bar or brace affect the driving any. That is mosly for the corning of the car right. I dont do any insane driving.
Mine is removed and I haven't noticed any difference. Its not to stiffen the car, it simply braces the panhard bar brackets so they don't bend. If you aren't autocrossing, I don't think you will notice it being gone. Also, are you sure the banging is the exhaust? You might want to check that all your mounts are good and tight, but also check your torque arm, both where it mounts to the trans and to the diff.
Old Oct 16, 2004 | 07:03 PM
  #17
kgkern01's Avatar
So Patriot, the upper panhard bar is what you removed for clearance of the driver's side pipe, correct? How is ground clearance on your car, is it too bad to be ran with a lowered car?
armedtrigger
Feb 24, 2015 08:30 PM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
Jazsun
Dec 29, 2014 12:14 PM
