longtube header problem
Old Aug 13, 2009 | 07:49 PM
nubucks's Avatar
sup u guys today i just put on my pacesetter longtubes and my off road y pipe so basically theres nomore catalytic converters and that just goes straight into my flowmaster muffler. i feel like when i cruise on the street that i lost power or back pressure but on the freeway i feel a big jump. can somebody help me plz
Old Aug 13, 2009 | 10:19 PM
Might want to add a "signature" with basic info about your car - year, model, engine, tranny and any major mods. There are differences in the LT1's (e.g. - speed-density 93) that would affect the answer.
Old Aug 13, 2009 | 10:25 PM
nubucks's Avatar
its a 97 z28 and i put pacesetter longtubes with the ory pipe its a automatic trans
Old Aug 14, 2009 | 05:19 AM
You don't lose torque/HP because of loss of backpressure. The longer primaries should also help low end.
It sounds like a "closed loop" problem. Start looking for anything you might have upset during the install - O2 sensor wires, contaminated sensors, knock sensor wire, grounds, etc. Check for leaking gaskets before the O2 sensors.
Old Aug 14, 2009 | 09:58 AM
nubucks's Avatar
i was going to have my o2 sensors and air/egr tuned out of my computer so will tht make a difference in how it runs?
Old Aug 14, 2009 | 11:50 AM
dangalla's Avatar
if your running your car without the primary o2 sensors then that will def be a problem. if not than i would suspect the o2 harness extensions that you installed for the primary sensors
i do not recommend tuning out the primary o2 sensors (closest to the motor) but the rear sensors are fine to tune out or drive without but you will get a engine light until you have them tuned out
Old Aug 14, 2009 | 12:01 PM
nubucks's Avatar
somebody told me i need to have all my o2 sensors tuned off. i really dont know what the hell is going on the car still runs strong its just i feel like i lost power on the street without my catalytic converters and my new header system
Old Aug 14, 2009 | 02:31 PM
dangalla's Avatar
somebody lied to you.
do you have the primary sensors hooked up or not?
WildRidez
Mar 27, 2015 08:22 AM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
k1996z28
Jan 21, 2015 07:22 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
