Long tubes on lowered car???
Old Apr 22, 2004 | 04:47 PM
Camaroal's Avatar
I want to put a set of hooker long tubes on my camaro but the car is lower 2in's Does any one have this doen to there car? if you have pics of how close they are to the ground that would be great
thanks
AL
Old Apr 22, 2004 | 04:55 PM
Naegash's Avatar
My Hooker Long Tubes scrape on enough things as it is and I am stock height. I couldn't even imagine how much they would scrape with 2" less clearance.
Old Apr 22, 2004 | 06:38 PM
Richard96TA's Avatar
I have my car lowered with the sportline springs and have Jet Hot long tubes and have no problems at all. Granted you will scrape a little on speed bumps, avoid them
Old Apr 22, 2004 | 07:33 PM
Naegash's Avatar
Also, keep in mind that roads in Utah (where I live) really suck. So if the area that you are normally driving has decent roads, you might have better luck than I do with your long tubes.
Old Apr 22, 2004 | 11:09 PM
SS MPSTR's Avatar
FLP's with Eibach Pro-kit...no issues here.
Old Apr 22, 2004 | 11:12 PM
formula383's Avatar
I have JET HOT's and Hotchkis springs. I don't have any problems with it. You really just have to pay attention what you are doing and you won't have any problems.
Old Apr 22, 2004 | 11:29 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
DMS springs here....
And.. I can't even slide a can of WD40 under my car. Yes.. It's that low!
Old Apr 23, 2004 | 12:19 AM
Red96Lt1's Avatar
Wow, I can't imagine jet hot's and 2 inches less of ground clearance. I already scrape and if I have passengers I scrape on everything, no matter what angle.
Old Apr 23, 2004 | 02:31 AM
carlos64030's Avatar
I have Hooker Logtubes and Eibach Sportlines. I scrape the driver's side collector flange and the y-pipe once in a while, but that's no big deal. I have no regrets. There are some pictures of the ground clearance of my car in my signature.
Old Apr 23, 2004 | 08:31 AM
jer4251's Avatar
sportlines, lowered 2 1/4" jet hot long tubes. 4" y pipe. headers are your least worries, you have to pick the right y-pipe, mine is tore up. but NOT go over any speed bumps!!
Old Apr 23, 2004 | 09:41 AM
Camaroal's Avatar
Thanks for the all the replies my roads are ok around here i don't drive the car that much bought it new in 97 and it only has 24k on it and that was from the first 2 years. i sold my racecar and want to do some other bolts on to my SS now and headers are going to be the first i think!!
what y-pipes are you using??
Al
Old Apr 23, 2004 | 11:26 AM
Naegash's Avatar
I just had a local exhaust shop fab up a custom y-pipe. Best $80 I ever spent.
Old Apr 23, 2004 | 02:17 PM
bunker's Avatar
FLP's have the best clearance by far, heck better then some shorties with Y-pipe, the headers will never touch, but the Y-pipe might, I got over almost all speed bumps & I'm lowered 1.8", I never scrape, the FLPs tuck up really nicely, you have to remove your oil cooler though because the FLPs tuck up so nicely the oil cooler is in the way.
Old Apr 23, 2004 | 05:37 PM
2cub49's Avatar
Here's the clearance wth my TPiS Longtubes.
http://img46.photobucket.com/albums/v142/2cub49/
I believe the Pacesetters have similar clearance at 1/2 the price of the TPiS's.
Old Apr 23, 2004 | 07:46 PM
Spinner's Avatar
Jet-hots and lowered car. 2 1/2 inch collector clearance. 2 inch driver's side y-pipe clearance ( goes down to clear tranny xmember). It's all about where you can and CANT go. Know that, and you'll be set. I dont have any issues, but I plan to swap to only a 1 inch drop for ease of getting around.
