Locktight or antiseize for header bolts..
Old Apr 21, 2003 | 11:37 AM
96z's Avatar
96z
Ive seen both used. Which is the right one?
Old Apr 21, 2003 | 11:40 AM
burnemonm1's Avatar
I have never used anything. I would not use anti-seize cuz when you go to pull them you may snap it off inside the head
www.streetlethalperformance.com
Old Apr 21, 2003 | 12:01 PM
Buttercup's Avatar
I think you mean threadlock
For the reason above I would NOT use threadlock on header bolts! I don't use anti-sieze either because the bolts already have a habit of backing out. I think I used a dab of oil on mine, that was it. Never had a problem.
Old Apr 21, 2003 | 12:04 PM
burnemonm1's Avatar
woops thanx for catching that
Old Apr 21, 2003 | 12:29 PM
Jason Short's Avatar
A little drop of oil on each one is all you need. Definatly no loctite or anything of the sort
Jason
Old Apr 21, 2003 | 12:46 PM
norcalstreet's Avatar
The heads are aluminum on a Z28 or TransAM while the bolts are usually steel or iron I believe. They expand and contract at different rates so using antiseize will prevent them from getting stuck.
Old Apr 21, 2003 | 01:16 PM
CGrant's Avatar
I have always used anti-seize and stage 8's, never had any problems.
Chris...
Old Apr 21, 2003 | 01:24 PM
Kris93/95Z28's Avatar
Chris...
My thoughts exactly!
Stage 8s and antiseize, no problems thus far
Old Apr 21, 2003 | 02:03 PM
Janny's Avatar
regular header bolts and anti sieze
Old Apr 21, 2003 | 02:30 PM
All_Z_Way's Avatar
Chris...
Yep...Me too.
Old Apr 21, 2003 | 02:37 PM
Joe Brodman's Avatar
GP Moderator
I have never used anything. Just some cheap Mr. Gasket header bolts and tighten them down. Never come loose, never get stuck in the head.
I've known people to use blue and even red loctite without a problem. Header bolts aren't THAT weak that you are just gonna snap them with ease because of a little loctite.
Old Apr 21, 2003 | 02:56 PM
On factory bolts, the first three threads are clean and then a 1/4" band of thread adhesive is used. No anti-seize is used.
Old Apr 21, 2003 | 05:34 PM
96z's Avatar
96z
Thanks guys, Ill just dap a little oil on them then.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
