Which Locks for these Bee Hive Springs ?
Old Dec 21, 2005 | 12:50 AM
HardcoreRM125's Avatar
I will be getting these Comp Bee Hive valve springs. Part Number: 26918-16
I wanted to get Comp 10* Locks, however I dont know which ones to order???
The springs are 1.290" O.D., and the only 1.290 Locks that they had on Jegs were for LS1's are their oly available in 7* and are like 150$.
I know there are people on here with same springs running 10* locks and retainers, so which ones are you all using?
Old Dec 21, 2005 | 01:06 AM
TransAm396's Avatar
Re: Which Locks for these Bee Hive Springs ?
i just got the beehive springs and i got the 10* locks and retainers..i heard someone on here say not to get them..but i talked to LLoyd Elliot on the phone and he recommended the 10* stuff..and personally id take his word over theres...btw hes a great guy to deal with..gave me advice and I didnt even have to buy anything.
locks-10*-613-16
retainers-10*-795-16
locaters(for use with the beehives on lt1 heads) 4705-16
Old Dec 21, 2005 | 01:12 AM
Thank you
It's been driving me insane trying to figure this out, cause it says only to use them, and their for a larger spring OD than the Bee Hives. You are running the same Bee Hives as I will be getting right? The Part Number is 26918-16
Old Dec 21, 2005 | 01:17 AM
TransAm396's Avatar
well the 10* retainers fit nice in the springs(im playing with them now)
Old Dec 21, 2005 | 06:22 AM
1racerdude's Avatar
Call Comp and get the CORRECT retainers and keepers for the springs. That is nothing to play with and getting the wrong stuff. Can cost ya 2 heads and an engine.
There is a rumor about 10* locks that they pinch the tip off of the valve and drop the valve.
That's only with titanium valves that have a steel tip and 900-1000lbs of spring pressure. When ya get to this point ya use 7*.
Old Dec 21, 2005 | 07:39 AM
TransAm396's Avatar
correct retainers and keepers?are you saying what i gave him was wrong? i gave him the part numbers to the correct parts.(i got the setup from combination motorsports)
Old Dec 21, 2005 | 07:47 AM
SStrokerAce's Avatar
I thought we already talked about all this boss?
10° is what I use with beehives.
Bret
Old Dec 21, 2005 | 07:52 AM
1racerdude's Avatar
I didn't say anything about what ya gave him,now did I.
I am trying to encourage him to get the RIGHT stuff. If your numbers are correct,so be it --but he can double check and see so he does get the right stuff.
Old Dec 21, 2005 | 08:10 AM
TransAm396's Avatar
..Oh..it just sounded(or n this case looked like) thats what you were saying. But yes they are the right parts unless he wants to go with titanium hardware then they would be the wrong stuff. Those are for the steel parts.
-Mark
Old Dec 21, 2005 | 08:24 AM
1racerdude's Avatar
-Mark
The CORRECT parts could be what ya gave him or something else,don't know.Didn't read your post. I do know that ya don't try to save money on retainers and keepers-- they WILL cost ya an engine if they are wrong or cheap stuff.
HarleyZ28
Oct 5, 2015 06:23 AM
rdaddee
Apr 20, 2015 09:43 AM
95chwagon
Jan 13, 2015 09:19 PM
