Locking Header Bolts WHICH ONES??
Re: Locking Header Bolts WHICH ONES??
Originally Posted by BlownF1
The Breslins use a regular 12pt socket or wrench (which greatly increase the access), no special tools needed...access isn't a problem for most;
Typical lock washers don't hold up to the heat cycles that the headers produce
. Unless you give me some data, like Stress Life Diagram (S-N Diagram usually log-log plot) for endurance where it shows after a certain amount of cycles lock washers give up, I find it hard to believe your statement
However, like your name implies and signature clarifies, you have a forced induction car; you are pushing more exhaust than NA cars, and stresses are higher on bolts as well.
Originally Posted by IEAT50Z
The breslins are nice. The 12pt end makes it VERY easy to get at them and tighten them. We only had a problem with maybe one or two. Stage 8s were **** and the jethot bolts were **** too. If you ever have to retighten them, you'll have to mess with all those clips and stuff. Plus a lot of people have a tendancy to round off stage 8s too.
Its your choice, but I tryed being cheap about it and its not worth the headache of doing those bolts over again. The breslins work flawlessly the 1st time with NO heat cycle.
Also make sure you get some quality fel-pro gaskets.
I guess I have a strong believe in my bolts
I have used Jet Hots, Stage 8's, Grade 8 allen bolts, and Grade 8 hex bolts, all with lock washers. Which actually lose their spring tension due to heat cycles of the engine. All of them are dog ****.
All I can say is Breslin has always held up for me, best damn bolt on the market.
Originally Posted by tanker
No one wants to back me up on using 3/8-16 in 1" length, grade 8 allan headed bolts with locking washers
Originally Posted by blown94
i think you got you answer, more than one person has said the lock washers WILL lose thier "spring" and I do believe them as the lock washers were not intended nor designed to take that kind of heat cycling. On regular exhaust downstream,....you can get away with it,....right up on the heads,....id be willing to bet you're headed for failure within the year. Let us know when you're wrong,....for your sake, i hope your not and they hold up,.....but physics will prove otherwise im sure.
. I will definitely let you guys know if I have any troubles with my setup and I will admit I was wrong. But till then, I will suggest my setup
If everything goes well, I might as well bag 12 bolts and 12 washers and sell them as a combo on ebay for $15
I dont care if your a freaking rocket scientist. Heat makes metal soft, why do springs on a car's suspension start to sag? Because heat builds up during use which changes the structure of the metal, with the weight on the spring, coupled with the heat creates sag over time.
The problem is amplified on a 1xxxxºF exhaust system.
I'm sure your a very smart person, however, real world testing on two of my F-bodies has resulted in lock washers and bolts = 0/4, Breslins 1/1.
You can lead them to water, but you can't make them drink!
<Office Space mode> If you're happy with the minimum pieces of flair...well, then...ok.
If you really want to prove/disprove the washer theory to yourself, back all the bolts off a full turn and then tighten them back down again. See if they've lost their spring...but before you do that, you might want to order some Breslins just in case.
Again, we're in violent agreement for the most part...not all applications require them, and not everyone is willing to pony up the $. Also, like I said, I tried the bolt/split washer route and 2 gaskets later I upgraded. If I'd of spent the $50 to begin with, it'd of been cheaper.
The original poster was asking if a particular locking setup would work, and IMHO based on direct experience with all the types being discussed, it'd be a mistake to go with it versus what's known and proven. End of story...
dang this is crazy! all of this for some locking heater bolts, well i think i'm going to go with the ones that trans9_5am told me about.
thanks for everyones help,
cw...
cw...
After this long thread I think everyone would expect you to know the name of the bolts in question. They are Breslin's and evidently a few think that it is funny you just said the ones such and such said. It was a good effort at a joke.
-Dustin-
-Dustin-
LOL...I thought the funny part was, the original question asked if he should go with Stage 8's, but the very first reply, said to go with Breslin's instead. The rest of us went back and forth, and now he's gonna go with the original recommendation.
