Locking header bolts needed ?
Old May 9, 2006 | 02:33 PM
EnerjetF67's Avatar
Do I need to use locking header bolts for my MAC Header install or should I use the bolts with the kit ?
The cost is not an issue, I just do not want them coming loose.
I however do not want to spend the ~$50.00 on ebay for the latest "whiz-bang" locking bolts if the supplied ones will work fine.
I'm going with the Percy's Carbon header gaskets.
Old May 9, 2006 | 02:43 PM
matt65's Avatar
Re: Locking header bolts needed ?
I used ARP bolts.
There are those that use the locking ones.
I would probably not use the ones in the kit.
Search around the board a bit. There is ALOT of header related posts.
Old May 9, 2006 | 03:10 PM
shartflhs's Avatar
A lot of people like the locking bolts but i just used mr gasket bolts and high temp loctite. Have not had a problem with them backing out.
Old May 9, 2006 | 03:13 PM
ttop1986's Avatar
i got Breslin bolts. They were like 60ish dollars or so. I believe they are stainless steel, and they are nice and easy to use, unlike the stage 8 ones. Ive had no problems with them thus far. Put them in, locked em, and left em that way.
Old May 9, 2006 | 03:37 PM
Sparkz28ss's Avatar
I run the same bolts....I never use anything else
Old May 9, 2006 | 06:27 PM
Quickss96's Avatar
i just ordered the same bolts. I wanted something i could tighten and never touch again but it cost me like 86.00 i got the 3/8 x 1'00. I hope they are worth the money.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
