lobe separation angle
Old Dec 18, 2003 | 12:33 PM
SantaCruz163's Avatar
What exactly does lobe separation angle mean? If the LSA is 114* what does that mean. Also how is valve overlate measured in, and what is a good number to consider in a performance engine?
Old Dec 18, 2003 | 12:53 PM
93redbird's Avatar
TTT for this..... I wanna know also, and just incase it is very technical, can someone dumb it down also.
Tim
Old Dec 18, 2003 | 12:58 PM
Smoke T/A's Avatar
LSA is the Lobe Seperation Angle or the number of degrees between the intake and exhaust lobe centerlines.
Old Dec 18, 2003 | 01:02 PM
LWillmann's Avatar
For some reason I thought that lobe seperation angle was the measure in degrees that the lobe centers were seperated...
Example: max lift on intake to max lift on exhaust in degrees = LSA
Old Dec 18, 2003 | 01:03 PM
If you have a longer stroke, do you want a larger LSA?
Old Dec 18, 2003 | 01:06 PM
LWillmann's Avatar
Typically, the more cubes you run, the larger the cam.
For example, a 383 will gobble up the smaller cams like the cc 304, Hotcam, etc... You get better results from larger cams like 236/242 and such when dealing with larger cubed motors.
This is just what I have seen from doing a lot of reading.
Old Dec 18, 2003 | 03:16 PM
timmyZ28's Avatar
Just do a search on Lobe Separation Angle on google.com. You will find plenty of information!!
LT14LIFE
Nov 15, 2015 06:22 PM
95chwagon
Oct 16, 2015 12:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Aug 7, 2015 01:26 PM
RX Speed Works
Jul 24, 2015 02:25 PM
