Lloyd Elliott heads/hotcam dyno numbers
Old Mar 9, 2004 | 08:42 PM
Ram Air 9C1's Avatar
I recently dynoed my Caprice with Lloyd Elliott heads (2.02/1.60" valves), hotcam and 1.7 rockers. The car was dynoed in a true street trim (belt on, air filter on, converter unlocked) through a 2.25" dual exhaust with 3 chamber flowmasters.
Here's the dyno sheet:
http://members.aol.com/feliks94ss/mydyno.jpg
Thanks again Lloyd.
Old Mar 9, 2004 | 08:43 PM
Mitch666's Avatar
Where is that shop?
Old Mar 9, 2004 | 08:44 PM
J.D.'s Auto Repair and Performance Center
810 Welsh Rd.
Huntingdon Valley, PA. 19006
(215)938-9270
Old Mar 9, 2004 | 08:46 PM
IllusionalTA's Avatar
thats some awesome numbers..
Old Mar 9, 2004 | 08:54 PM
Mitch666's Avatar
Yo! Ive heard a lot about that place. I was actually going to call and see if they had a dyno. How are there rates for installs and dyno? Nice Numbers too! I know you sent your heads to Lloyd and I would like to do the same, but does J.D.'s offer port+polish, I am just trying to avoid shipping on the heads.
Old Mar 9, 2004 | 09:00 PM
Bryan Herter tuned the car on the dyno. The tuning and 3 runs cost me $250. I'm not sure if they offer head porting services.
Old Mar 9, 2004 | 09:07 PM
'93 formy ...'s Avatar
Re: Lloyd Elliott heads/hotcam dyno numbers
Where did you pick up the 1.7RR? How much were they? Did you have to modify the valve covers to get them in? I'm thinking of upgrading to the 1.7's I just want to make sure I know everything before I go ahead with the purchase. What's the lift on the LT4cam with the 1.7's ?
Old Mar 9, 2004 | 09:21 PM
I got Comp Cams 1.7 stainless rockers. I needed tall valve covers for the polylocks to clear.
The hotcam lift with 1.7 rockers is .558".
Old Mar 9, 2004 | 09:31 PM
stereomandan's Avatar
Looks great!!
It also looks like you may have seen a better max TQ number if you would have started the dyno run at a little lower RPM.
Thanks for sharing.
Dan
Old Mar 9, 2004 | 10:26 PM
Mikey 97Z M6's Avatar
Nice numbers for a Hotcam, but I wonder what the SAE corrected numbers would be?
Oops, nevermind, I just saw your sig....
Mike
Old Mar 9, 2004 | 10:31 PM
Mtrhds94Z's Avatar
Mike
Scroll down the link he gave.. it has the corrected #'s there on another dyno chart..
Old Mar 10, 2004 | 05:49 AM
jcolez28's Avatar
I was wondering why you stayed with such a mild cam instead of getting his high power custom cam. Im considering his 2LE kit . Thats impressive for the hot cam!
Old Mar 10, 2004 | 07:20 AM
95 Silver TA's Avatar
Nice numbers broh!!
Had a quick question for you...Was that 250.00 total for both Bryan and JD or was it just 250 for JD and more for Bryan.
Also sent you an email.
Thx,
Claude
Old Mar 10, 2004 | 08:17 AM
LT4POWR's Avatar
With your mods those are good #s
Old Mar 10, 2004 | 08:33 AM
ZZtop's Avatar
I'm pretty sure thats the most power anyone has seen out of a hotcam in a stock block. Congrats!
