Lloyd Elliott does it again!!!
Old Jun 28, 2005 | 08:32 AM
RealQuick's Avatar
Thumbs up Lloyd Elliott does it again!!!
Well, my boss is looking for a fun street car with full spool in the 2600-2800rpm range. He only plans to run 8-10psi intercooled in his 67 camaro. The T74 was the smallest I recommended for spool time. He just got his flow #'s for his Dart Pro 1 heads he is going to use on the 383. Lloyd Elliott ported them BTW...
237 cc intake port
74 cc chambers
Flow #'s are . . . . .
.2......142/105
.3......199/145
.4......248/175
.5......281/202
.6......302/217
.650...314/226
.7......317/229
2.08/1.625 Ferrea 6000 series valves
Comp 26120 big bee hive springs
Titanium retainers
10 degree locks
spring locators
Once again, Lloyd does a great job at a great price.
Old Jun 28, 2005 | 09:53 AM
97WS6SCharged's Avatar
Re: Lloyd Elliott does it again!!!
Very nice. I hope my 215s turn out as well when they're ported.
Old Jun 28, 2005 | 10:07 AM
RealQuick's Avatar
AFR's or Darts? My AFR 210's Lloyd ported were close in all lifts.
.............Lloyd's AFR 210....................Lloyd's Pro 1's
.............Intake....Exhaust...............Intak e.....Exhaust
0.200......143........103.....................142. ........105
0.300......204........141.....................199. ........145
0.400......247........173.....................248. ........175
0.500......281........198.....................281. ........202
0.600......308........219.....................302. ........217
0.700......311........227.....................317. ........229
Old Jun 28, 2005 | 11:10 AM
Dart Pro 1 215s. 2.05/1.6 64ccs
Going on my twin turbo motor.
Old Jun 28, 2005 | 02:24 PM
jninan2k2's Avatar
i hear a lot of great things about lloyd elliot...guess ima head their way when i finally get to the heads for the ole lt1
Old Jun 28, 2005 | 02:33 PM
Black1995Z's Avatar
Does Mr Elliott have a site?
Do you have to get your heads ported for a certain cam? Or can heads just get ported to be ported? What I mean is-- do the numbers the heads flow need to match with cam specs/crank specs/cfm?
slverbullet's Avatar
i'd recommend it! he does great work and offers great customer service.
lloyd and bret are both great to work with.
Old Jun 28, 2005 | 02:37 PM
RealQuick's Avatar
www.eportworks.com
nighttrain66@msn.com is his email
Typical you have the heads ported and the cam should be spec'd to the heads. You should specify forced induction or N/A.
Old Jun 28, 2005 | 02:48 PM
chevy1963's Avatar
I would also say lloyds great! His screen name here is nighttrain66
Old Jun 28, 2005 | 08:24 PM
besz28's Avatar
hey real quick awesome car. our set ups are pretty close about the same hp and torque two. iam thinking about switching out my 230/236 xe cam for a loyd elliott le2 cam since he did my heads what do you think? iam asking you because you seem pretty knowledgeable, and have an awesome car. well take care of yourself.......brian
Old Jun 29, 2005 | 08:59 AM
RealQuick's Avatar
Brian, I loved the cam and mine had a 114LSA. I suspect with a dyno tune I should have seen close to 390rwhp/360rwtq. The LE2 cam should be good for 400rwhp/370rwtq. Is the extra 10-15hp/tq worth the cost of a new cam? Perhaps…I don’t know if the LE2 cam will make more lowend, considering my tq curve was pretty damn flat.
http://memimage.cardomain.net/member...58_45_full.jpg
I would call Bret Bauer and ask his opinon since he designed the cam.
Old Jun 29, 2005 | 10:16 AM
besz28's Avatar
wow realquick just went to your car domain site didn't realize you were doing all that stuff. i am really contenplating doing a 383 stroker, my friend had his done from golen, iam at a crossroads stroke it or put the money into an ls1???? good luck with everything hope all turns out awesome for you.
Old Jun 29, 2005 | 10:46 AM
buzz12586's Avatar
Man, I keep hearing about how great his work is but I don't have the money for the LE1 package yet. Grrrrr.
Old Jun 29, 2005 | 10:49 AM
BUBBA's Avatar
Riddle me this: I can understand getting big flow numbers out of aftermarket performance heads, but how much has anyone ever gotten out of stock heads? Just curious.
Old Jun 29, 2005 | 10:57 AM
RealQuick's Avatar
Lloyd typically gets mid to high 270's (185-195cfm on the exhaust). I believe his fastest stock bottom customer has gone 120mph in the 1/4.
