Lloyd elliot LE2 ,optispark kaboom
Old Dec 18, 2006 | 08:50 AM
  #16
Javier97Z28's Avatar
Moderator
Originally Posted by Jlo
But, do you know the exact Size or Length of the cam pin and is there a way to measure it??
Old Dec 18, 2006 | 08:59 AM
  #17
NightTrain66's Avatar
as mentioned . . . check pin length and make sure the pin is NOT bottoming out in the pin slot of the opti.
Make sure the bolts that hold the opti to the timing cover are not bottoming out and allowing oil to come in from the seal.
Get a MSD cap and rotor since the MSD rotor is MUCH better and will not fly apart like other ones. this can cause problems when shifting 6300 and higher.
Make sure the vent tubes are hooked up like mentioned also.
Check these things and good luck
Old Dec 18, 2006 | 09:10 AM
  #18
Jlo's Avatar
Jlo
Originally Posted by Javier97Z28
Great info, I'll have to write that down on the cam box.
Old Dec 18, 2006 | 12:12 PM
  #19
ozzyblackz28's Avatar
thanks for all replies!i appreciate that i will tell my mechanic to check de dowel pin again and maybe if it was only the rotor exploded to buy the msd cap and rotor .do you think is that the summit opti is a junk for moded cars?
Old Dec 18, 2006 | 02:06 PM
  #20
Everyone remember that it is up to you to make sure the dowel pin is the correct length. It has nothing to do with any manufacturer "getting it right". They all warn that the dowel pin length must be checked to fit your application.
Repeated opti (vented) death after a cam install is most often a dowel pin issue.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
colts0455
Sep 27, 2015 01:07 PM
