Little to No Response on Acceleration?
Re: Little to No Response on Acceleration?
The O2's should go up and down from 0xx to 9xx and as long and you get something like this you are fine. 2xx 7xx 8xx 4xx 6xx 3xx 7xx 2xx and so on. You don't want them to stay in the same area and bouncing around means they are working correctly.
I checked my old datalogs and had four reading below 75 on one side of the O2's. I ended up having a bad alternator and once I replaced it all my issues went away. I only had issues at high prms when it would stumble. Probably not your problem, but it was mine.
My Z had similar symptoms. Would run fine then out of no where would start to bog. Even with pedal floored, car would do nothing, low idle. Turned out to be one of the plugs arcing. You mentioned you checked wires, did you recheck plugs. After I checked plugs, Z was back to purring. Good luck buddy.
If anyone's interested, I figured it out. My cat was really clogged, maxing out my pressure gauge at 10 psi. This is most likely the cause of the oil leak too, forcing oil out, so that may not even need a repair. I believe the cat got clogged before I replaced the ignition coil wire/plugs and wires, since the engine should have been running very rich.
My only problem now is disconnecting the y-pipe from the manifold. The studs are pretty bad, and I snapped one last night. So now I want to replace the whole set. Since I'm not worried about hurting them, anyone know how to get the studs out?
CARiD
Sep 7, 2015 08:21 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
