A little help ...please....????
Old Jun 5, 2006 | 10:32 AM
popo8's Avatar
Listen my 96 Z28, has developed a mis-fire. Now I changed the plugs, and wires withing the last.... 20,000 miles (thats how long I've owned it)... while ideling today after court, the car made a couple backfires, and shook, then the low oil light came on... (I shut the car off) and the light went out... I know those sensors go bad... so Im not really worried about the oil. and my oil pressure was arount 10-20lbs idle (normal for an LT1)... I stopped at Knopps, and hooked the scanner up to it, and it has a serious history of mis-fires... but nothing current, (even with the car shaking and acting up) The plugs are such a pain in these cars... so I wanted to see if anyone else had the same kind of issues.... Also got a code for an O2 sensor (post cat).. so that should not effect how the car is running.... didnt know if I should still go old school and pull all the plugs and wires, or if I should put a new OPTI-SPARK in it, since I think its the original one with 140,000 miles on it. A little advise would be helpful.. since I bought my girl a 95 Z28, and I can t have hers being faster than mine...
Old Jun 5, 2006 | 11:41 AM
Demus's Avatar
Re: A little help ...please....????
It's possible the cat is clogged
Old Jun 5, 2006 | 01:17 PM
popo8's Avatar
High flow cats... with less than 20,000 miles on them... you think thats possible????
Old Jun 6, 2006 | 09:23 PM
popo8's Avatar
Well checked fuel pressure... GOOD.... said screw it and ordered a GM opti from a person selling one new in the box.... $215 shipped.... couldnt beat the price.... Ill check the wires and plugs during the swap.... Im pretty sure the swap will be a pain in the ars.
Old Jun 7, 2006 | 09:55 AM
DrewHMS97SS's Avatar
optis are a pita. you have closly inspected all of the wires for over heating?
Old Jun 7, 2006 | 03:43 PM
popo8's Avatar
all of the opti's wires... or plug wires??? I have yet to see one up close, and off of the car.....
murray
Sep 29, 2005 09:26 PM
