little help please!!
Old Apr 4, 2003 | 05:19 PM
qwick_trip's Avatar
ok there is a small ticking noise. and if i rev the car up then i don't really hear it because of the engine, so it dosen't get louder. what could it be?
Old Apr 4, 2003 | 05:22 PM
norcalstreet's Avatar
Exhaust leak. Most likely your header gaskets are leaking or your header bolts need to be tightened down.
If tightening them down doesn't solve your problem replace the gaskets and use Stage 8 locking header bolts.
Old Apr 4, 2003 | 05:40 PM
joeSS97's Avatar
Injecter or a rocker out of adjustment.
Old Apr 4, 2003 | 05:43 PM
qwick_trip's Avatar
i put new mac headers and it's the same as it was with the manifoilds. same ticking noise. i got the stage 8 locking bolts i just have to put the retainers on it still but i tightened them up twice. i will go back through it to make sure there all tight but if thats not it what else could it be???
Old Apr 4, 2003 | 05:46 PM
qwick_trip's Avatar
i got new bosch svo injectors ticking before and after, also got new roller rockers and did it before and after that two.
