little help
Old Jul 19, 2011 | 07:16 PM
snoshimmy's Avatar
little help
Ok my car since i bought it has gotten pretty bad gas mileage if you stand behind it at idle you can smell fuel in the exhaust and recently it has been having a hard time starting any idea what would cause this or how to fix it is it a tune thing? i read somewhere if the maf or the ect are bad it can cause this but i dont have a ses light on
thanks art
Old Jul 19, 2011 | 07:49 PM
bw_hunter's Avatar
Re: little help
thanks art
Hi Art, Anytime you have poor fuel mileage, the place to start is with a tune up. We don't have information on your car as to mileage etc, but I'd clean or replace the air filter, replace the plugs and spark plug wires, and replace the fuel filter.
You might also consider changing the oxygen sensors as well.
Old Jul 19, 2011 | 09:37 PM
snoshimmy's Avatar
Re: little help
around 20k miles on rebuilt engine and trans was done by previous owner at a local shop. Ive been thinking my fuel pump may be going bad and thats why it is having a hard time starting because when i cycle the key on two to three times i can hear the pump and i usually have to give it some throttle to get it started any other info you need that will help let me know
Old Jul 19, 2011 | 11:55 PM
mrmint69's Avatar
Re: little help
Plugs should be good if only 20,000 miles on them. You could pull one that's easy to get to and check the condition and the gap. They can tell you a lot on what might be wrong by the color, if it has oil or gas and how the tip is. I would replace the fuel filter, check all the plug wires for damage and check the fuel pressure while driving. How many miles on the car? Maybe the O2's should be replaced if they are original and you have high miles on the car. Is the opti new when you did the rebuild?
Old Jul 30, 2011 | 11:42 PM
snoshimmy's Avatar
Re: little help
been away for awhile dealing with family issues but now im back to fixing the camarooptis new i will check the o2 when i can get it to my lifts the car has 130k on the body i also just put on a new cold air intake and noticed that the air pump hose was unhooked
Old Jul 31, 2011 | 08:58 AM
Re: little help
Does the car still have a catalytic converter?
Running rich can be caused by misfires, exhaust leaks before the O2 sensors, faulty O2 sensors or wiring.
Old Aug 1, 2011 | 01:16 PM
snoshimmy's Avatar
Re: little help
car still has cats i left them on for smog here but i do have a ticking coming from the engine bay which i beleive to be a exhaust leak.
