little help
Old May 9, 2008 | 09:04 PM
Bigrick2324's Avatar
little help
i have 95 lt1 it has cc306 longtube headers full exhaust just everything to go with this do i need bigger injectores for the cc306 cam or should i be good ??plz help
Old May 9, 2008 | 10:13 PM
93transam1234's Avatar
with out head work you should be good, if you want to be 100% sure then hook a scanner up to the computer and see what duty cycle the injectors are running at under 80-85% and you should be fine
Old May 9, 2008 | 10:31 PM
no head work at all
