Link Bar Morels
Old May 18, 2006 | 10:39 AM
joe-96z1le's Avatar
Link Bar Morels
Is there anything special (machining, etc) that needs to be done to an LT1 motor to swap over to link bar Morel lifters HR from OEM? Or do they pretty much just drop in?
Old May 18, 2006 | 07:12 PM
SStrokerAce's Avatar
Re: Link Bar Morels
Yep they drop in. You need to pull the heads to do that though.
bret
Old May 18, 2006 | 08:35 PM
BlackScreaminMachine's Avatar
Re: Link Bar Morels
All I can say is this, I was able to slip my Morels after the heads where on, but maybe its due to the meterial taken out of the head. By the way it was VERY tough.
Old May 18, 2006 | 09:16 PM
LT4POWR's Avatar
Re: Link Bar Morels
This question was just asked the other day. I was able to install mine with the heads tq'd down. Not easly or quick...takes a lot of time trying different angles.
Old May 29, 2006 | 11:27 AM
OneFlyn95z28's Avatar
Re: Link Bar Morels
takes a little thinking but they go in just fine with the heads on
Although I did Cus' Bret a little over it
Old May 29, 2006 | 12:43 PM
Re: Link Bar Morels
I usually have to loosen up the head to put them in and take them out. Thank god for Cometics!
Bret
Old May 30, 2006 | 02:17 AM
Re: Link Bar Morels
It just took a little "lifter acrobatics"
Old Aug 20, 2006 | 07:47 AM
JustNO's Avatar
Re: Link Bar Morels
bret
while I'm doing a search, I saw your post and really really want to know why.
My Morels aren't linked bars, but isn't enough to pull only the intake? Or did I something wrong?
Old Aug 20, 2006 | 11:37 AM
Re: Link Bar Morels
No it's just easier to install them when the heads aren't on the block. There are Morels that are not link bar versions, they work great in LS1 cars. The link bar versions I just like better since they add some security over the stock lifter retention setup.
Bret
Old Aug 20, 2006 | 12:16 PM
JustNO's Avatar
Re: Link Bar Morels
Bret
I still couldn't make a relation between heads and lifters. Aren't they just bolt on? After reading this I'm not sure if I replaced them correctly. Angles?
Old Aug 20, 2006 | 02:00 PM
SS RRR's Avatar
Re: Link Bar Morels
I'm pretty sure link bar lifters have a taller body than the dog bone style.
Old Aug 22, 2006 | 03:55 AM
JustNO's Avatar
Re: Link Bar Morels
Yes it is taller for sure, but what about angles?
I mean I installed my lifters without removing the heads and it was so easy. Did I something wrong?
Old Aug 22, 2006 | 07:16 AM
Eric@Victory Racing's Avatar
Re: Link Bar Morels
You purchased the non-link bar style, so they drop in very easily. The link bar style take a little finess with the heads on.
SpeedJunkee
Jul 19, 2015 09:06 PM
GT what?
Jul 14, 2015 10:17 PM
cmsmith
Jul 10, 2015 07:19 PM
Slayer
Jul 4, 2015 03:06 PM
