Lingenfelter
Old Oct 11, 2006 | 04:21 PM
Sgt. Spuds's Avatar
Lingenfelter
Is their CAI any good? I know most intakes are the same, but is their anything bad about Lingenfelter's offering? Just wanting to know.
Old Oct 11, 2006 | 04:46 PM
MEAN LT1's Avatar
Re: Lingenfelter
Just another CAI to me.
Old Oct 11, 2006 | 05:25 PM
reamo04's Avatar
Re: Lingenfelter
it has a cheaper MSRP than anything else I have found.
Also, some people have claimed that it produces more power than the moroso, and the SLP.
Personally, I would rig my own up. Take some PVC pipe, and a K&N filter, and just create your own tubing and everything. I would personally do it this way, its cheaper, and then you can run it lower. If you have a piece of sheet metal, you can also create an air-duct on the bottom of the car to help it "suck" more air in.m This way you are getting more air from closer to the road which will probably be cooler.
Or buy one that will look semi-better (my friend made his own and painted it flat-black and it looks fine) and perform about the same.
Old Oct 11, 2006 | 05:26 PM
Severous01's Avatar
Re: Lingenfelter
just another CAI.....buy used there's no difference...even if the filter's dirty you can clean it.
Old Oct 11, 2006 | 05:39 PM
Bersaglieri's Avatar
Re: Lingenfelter
I got my LPE CAI for free so I cant complain, but it does have the largest K&N filter of any CAI mass produced for LT1's. Its also usually the cheapest, but in my opinion built solid.
-Dustin-
Old Oct 12, 2006 | 12:20 AM
ibanez6rg's Avatar
Re: Lingenfelter
It's OK. I really don't like the looks of it, but it works just fine like any other CAI. And yeah, the filter on it is massive.
Old Oct 12, 2006 | 12:38 AM
Sgt. Spuds's Avatar
Re: Lingenfelter
any pictures of it installed?
Old Oct 12, 2006 | 01:18 AM
SS RRR's Avatar
Re: Lingenfelter
This thread never goes away... Oh well... since someone asked I might as well whip it out...
These are more for showing the valve covers but you get the idea.
Old Oct 12, 2006 | 09:54 AM
Bud M's Avatar
Re: Lingenfelter
Its a well designed unit and it's one of the few (maybe the only, I don't know for sure) that comes in a 93 specific version too.
Old Oct 12, 2006 | 01:01 PM
CALL911's Avatar
Re: Lingenfelter
All the CAI's are pretty much the same. None in my opinion is superior to any of the others. If you have gotten a good price on it, and you don't want to make your own, I say go for it.
Old Oct 12, 2006 | 02:50 PM
Severous01's Avatar
Re: Lingenfelter
actually...the SLP units have the most flow capability and the largest filtration per square inch. also, they are specificly designed for the non-MAF cars in mind. you'll have to either grind a little of it away or cramp down the elbow to fit it with a MAF car. also, it's outlet pipe is 3 and 1/4" as opposed to 3" OD pipe...so it will definitely flow more...it's just a PITA to install if you're not prepared to either do some cutting or have someone to compress the elbow to fit the SLP unit. it also has a really nice clip that slides into the otherwise pointless bracket right behind the headlight...on the metal piece that mounts to the radiator bracket as well.
i've personally had 4 different CAIs on my car and the easiest, most appealing, most practical was the k&n...which i have now.
Old Oct 12, 2006 | 05:49 PM
Bud M's Avatar
Re: Lingenfelter
What are you basing that on?
Old Oct 12, 2006 | 07:28 PM
SS RRR's Avatar
Re: Lingenfelter
The SLP is a good piece, but a PITA to deal with when installing/uninstalling.
Old Oct 12, 2006 | 07:54 PM
Sgt. Spuds's Avatar
Re: Lingenfelter
Yea I was looking for a slp one, basepurely on how it looks, as I am pretty big into apperance, but this one was cheap, and I absolutly NEED it now, so wtf, can't hurt.
Old Oct 12, 2006 | 09:13 PM
CamaroRacing12's Avatar
Re: Lingenfelter
go for it....u can always make an air duct for it too....
