Light weight 1.6 roller rockers?
I did a search and all I found was "best" roller rockers. I'm trying to save weight in the valve train. I am running LT4 valves and titanium retainers on the new set of heads. They are going on a lighter weight bottom end. Trying to figure out which rockers offer some weight savings and don't really sacrifice quality to get there.
I'm only running a Crane227 cam so they don't have to be able to take huge amounts of abuse. I am running 7/16ths studs too if that matters. Anyone have a suggestion?
[QUOTE=1989TransAm;5791370]My 1.65 Harland Sharps are not all that heavy. I bought some 1.65 Crower Enduro rocker arms and they are heavier than the Harland Sharps. Tony Mamo at AFR says to go with an aluminum rocker arm.[/QUOT
How mush power did those harland sharps 1.65 add i was thinking about going with those for a little more lift than the 1.6s...what all would i need with those, springs?
Sure a light valvetrain is nice, but you want strength too.
If you want a lighter rocker, use the Crane Golds or equivalent aluminum-bodied. They are overall lighter, but some people say they shift weight over the tip of the valve stem. I personally use the Crane Golds.
I'm only running a Crane227 cam so they don't have to be able to take huge amounts of abuse. I am running 7/16ths studs too if that matters. Anyone have a suggestion?The Comp Hi-Tech are advertised as having low "rotating weight" but I've never seen any numbers to support the claim.
Why would I use the 1.7s?
This is what I am looking for. Over the tip is what I am concerned with.
i guess i need to slow my typing down...and thanks.
