which lifters to use?
Old Jul 14, 2005 | 03:40 PM
sick-1's Avatar
Fixing to peice together my 383 LE3 setup and need to know whether or not to buy buy the Comp R lifters or will my stock rollers be up for the challenge. Anybody with a similar setup or the experience please help.
Old Jul 14, 2005 | 03:44 PM
Paul N's Avatar
Re: which lifters to use?
My old 94 had the "common" valve train noise I read about here on this site and when I went to a comp cams roller shaft and matching springs, the noise worsened. I narrowed it down to the stock original lifters not being up to the task of the stiffer springs and caused them to bleed down more than before. Considering the amount of b.s. involved, I would just put in the new ones and avoid a possible headache.
Old Jul 14, 2005 | 05:13 PM
94zgreenmachine's Avatar
Lloyd should have spec'd out your lifters for you. If not call him but with my LE2 383 I had to use comp r's so I am thinking you'll have to also. If so, just watch the valve adjustment. .002-.004 lash. Not your typical 3/4 to full turn once zero lash is felt.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
