Lifters for CC306
Old Aug 24, 2005 | 11:22 AM
belac350's Avatar
Lifters for CC306
Ok I have searched this and still have not got good info. I am putting a cc306 and all else needed to support it, but what lifters? OEM or comp R.
Old Aug 24, 2005 | 11:39 AM
Z95m6's Avatar
Re: Lifters for CC306
I'd just go with New OEM's or keep your stockers. I had comp R's and 9 of them ended up having missing or cracked retaining clips. I'm not the only one here either there has been many people having this problem. Bret Bauer told me i could run OEM lifters with my cam and it has a lot more lift.
Old Aug 24, 2005 | 11:44 AM
IEAT50Z's Avatar
beehive springs and OEM replacement lifters.
JustNO's Avatar
what is your springs?? You should change your lifters according to your springs, but yes lots of people have trouble with R lifters.. You should go with OEM I think your springs aren't big for your cc306 cam..
Old Aug 24, 2005 | 11:45 AM
JustNO's Avatar
and a rev-kit to protect lifter float
Old Aug 24, 2005 | 11:49 AM
IEAT50Z's Avatar
Yup, relatively cheap insurance.
Old Aug 24, 2005 | 12:11 PM
FutureZMan's Avatar
shouldnt even consider any build without this. Hell of alot cheaper then all out replacement.
Old Aug 24, 2005 | 01:15 PM
belac350's Avatar
Not sure on the springs. The head builder is installing them. CNC heads in Florida is doing the work on the heads.
Old Aug 24, 2005 | 02:28 PM
tardy007's Avatar
I'd recommend against Comp R lifters, see sig
Old Aug 24, 2005 | 02:30 PM
JustNO's Avatar
lol great sign
Old Aug 24, 2005 | 02:34 PM
JustNO's Avatar
Why compcams do not try to fix these new style R lifters.. They are really garbage..! People who have not a trouble with these lifters, use the old style R lifters,not new style!!!
If you got much spring pressure, get a set of MOREL lifters!!! Top notch quality lifters! (Also you will not need rev-kit)
Old Aug 24, 2005 | 03:15 PM
93 4mula's Avatar
Man...Im in the process of building a (built) nitrous 383...what lifters do yall recommend running? I was going to run the Comp R's but now seeing this I dunno anymore. Are there any difference in using OEM and Comp R's?
Old Aug 24, 2005 | 03:36 PM
LT4POWR's Avatar
I've got a slightly used AFR Rev Kit w/ the install tool for sale. PM me if your interested.
Old Aug 24, 2005 | 03:38 PM
JustNO's Avatar
My engine assembly is almost ready and unfortunately my engine builder used comp R lifters (it was my choice) .. Anyway if I got a problem (I think I will) I will change my springs and will get a set of beehives (26918) and comp OEM lifters (850-16) with an hydra rev kit..
My current springs have 160lbs close seat for that reason I couldn't use OEM lifters.. But beehive springs have 130lbs and have less weight,so OEM lifters will be the choice with beehive..
No R lifters, no trouble..
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
