lifters
Old Jan 15, 2009 | 02:45 PM
deerslayinrenek's Avatar
lifters
I'm putting lifters and roller rockers in my Lt1 and want some opinions. Ive been told to get some gmpp lifters....where can i order these from and are they LS7's or just replacements. Whats your thoughts on roller rockers, i was told to go with 1.6's but what brand. It's pretty much stock but i have some upgrades in mind when the funding is a little better.....thanks Mike
Old Jan 15, 2009 | 02:47 PM
oh and also do I need any guide plates. I'm kinda new to this ballpark
Old Jan 15, 2009 | 03:40 PM
93FIRETURD's Avatar
try to find a set of comp or crane 1.6 rrs look for self aligning rockers then you wont need guideplates or hardened pushrods
Old Jan 15, 2009 | 03:42 PM
93FIRETURD's Avatar
oops and yes the ls7 lifters are very very good they are a little longer than stock so it will make your cam in essence a little bigger(more lift)
Old Jan 15, 2009 | 03:46 PM
Stl94LT1's Avatar
Ah, NO they won't. But, you may need a different length pushrod.
Old Jan 15, 2009 | 03:57 PM
i found LS lifters from Gmpartsdirect.com for $114 part #12499225
does this sound like the right ones and a fair price?
oh and also if i put 1.6 rr's on will i have to get taller valve covers?
Old Jan 15, 2009 | 08:34 PM
DAVE00's Avatar
That is the correct part for the LS7 lifters and they are a great replacement. You might need longer push rods as they have a .1000 deeper pushrod cup than the stockers but many people on here argue this fact. Lloyd Elliot told me I might need longer PR's on mine, but the best bet is buy an adj pr and check for your length and order the right length. Also the Crane gold will work just fine with your stock VC's without any modifictions, as I have em' on my 383 with chromed stock VCs. The only ones that require mods are (I believe) the Comp Pro Mags and any shaft mounted rockers.
Old Jan 17, 2009 | 02:31 PM
camarobird92's Avatar
I have heard of people having oiling problems with the LS lifters.
Old Jan 17, 2009 | 02:57 PM
I read a thread of ONE person that had some sort of trouble. Not sure it was really related to lifters or not.
Old Jan 17, 2009 | 03:01 PM
hopefully not, cause i have LS7's on there way
Old Jan 17, 2009 | 03:37 PM
96capricemgr's Avatar
Why are you replacing the lifters atall???
Old Jan 17, 2009 | 03:59 PM
cause it has a tap most of the time and a nasty tap when I first fire it up... until the lifters pump up i assume. And last week was the second time that a rocker arm jumped off, they were different rockers each time
Old Jan 17, 2009 | 05:22 PM
Stock lifters are very reliable you would do well to find the source of the problem. Probably is a good idea to go ahead and replace them though just incase they were damaged. Improper adjustment would be my number one suspicion.
"lifter ticking" is usually an exhaust gasket leak and it can go away as parts warm and expand.
Old Jan 17, 2009 | 08:06 PM
maverickmk's Avatar
if you go to a 1.6 rocker you may want to get some better springs - the stock LT1 springs aren't very good at upgrades in the valve train - as for LS7 lifters they are a good replacement, for guide plates that depends on the type of rocker you purchase. NSA (non-self-aligning) rockers need guide plates, and SA (self-aligning) rockers do not.
Old Jan 17, 2009 | 11:31 PM
it taps bad for the first like 3-7 seconds then clears up, but not everytime
as of now I'm going with LS7 Lifters, Crane 1.6 S/A RR's, LT4 Springs, and longer pushrods if need
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
