lifters
Old Jan 22, 2006 | 11:30 AM
Chevycobb's Avatar
lifters
I installed some comp r's a couple of months ago while doing my engine build and decided to get my heads ported. If I put the lifters back in oil for a while will they still be ok? They still haven't been used yet.
Wish I could get some other lifters though after hearing so much bad stuff about these. Would stock lifters be ok to use too? I don't want to spend too much money on another set of lifters.
Old Jan 22, 2006 | 11:41 AM
TheNuge876's Avatar
Re: lifters
As long as they arent damaged at all roller lifters can generally be reused. I dont know if you have to change them for a bigger cam or anything like that, but they dont create any specific wear patterns on the cam lobes, so they can generally be used as long as the condition is good.
Old Jan 22, 2006 | 05:35 PM
1racerdude's Avatar
Re: lifters
Stock lifters if they are in good shape will be fine.
Old Jan 22, 2006 | 05:37 PM
Chevycobb's Avatar
Re: lifters
it's just a matter of adjusting the preload on these things is what i'm affraid of. i've looked at shoebox's website...but I don't know, probably more paranoid than anything
Old Jan 22, 2006 | 05:52 PM
1racerdude's Avatar
Re: lifters
Use a .001 feeler guage and feel the 0 spot. It won't be much drag but ya should be able to feel it. If the intake is off ya can do it with the spin method and watch the cap in the lifter for movement. This is how ya learn how to "feel" the pushrod for drag. Then 1/8 turn.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
