Lifters?
Old Dec 14, 2004 | 07:36 AM
Myxtreme1's Avatar
Lifters?
So what lifters are everyone using? I was looking at the stock ones from gm parts direct, but if the prices are the same then I will probably call Combination. My cam is the 227/233.
Old Dec 14, 2004 | 09:58 AM
brandboZ28's Avatar
Re: Lifters?
Im using Comp R's with the same cam. Im using Crane springs that have a very high seat pressure and was afraid that the stock lifters wouldnt cut it. If you have the funds, Comp R's are just one less thing to worry about but it not, stock replacements should work fine.
Old Dec 14, 2004 | 10:55 AM
Myxtreme1's Avatar
Re: Lifters?
Yeah I was thinking about going with the Sealed Power/ Speed Pro lifters. They are quite a bit less than the others but I'm not sure yet.
Old Dec 14, 2004 | 11:10 AM
Z95m6's Avatar
Re: Lifters?
I would run Comp R's. The 227/233 has lots of lift and with XE ramps you need some good lifters.
Old Dec 14, 2004 | 11:31 AM
Myxtreme1's Avatar
Re: Lifters?
So stock style lifters wouldn't work well with my cam?
Old Dec 14, 2004 | 12:22 PM
Z-RATED94's Avatar
Re: Lifters?
Ask somebody in the know. I believe it has to do with ramp speed and spring pressure.
Old Dec 14, 2004 | 01:14 PM
Evil Eric's Avatar
Re: Lifters?
im using stock lifters with my cam 218/228 112lsa.
Old Dec 14, 2004 | 02:35 PM
Myxtreme1's Avatar
Re: Lifters?
We're yours fairly low miles? Mine have quite a few on them.
Old Dec 14, 2004 | 02:46 PM
dmoor88's Avatar
Re: Lifters?
if youll be running your RPM's above ~6k, id go with the Comp R's. if youre keeping your stock heads then you may be all right going with stock replacement lifters, since yo uwouldnt run RPM's above ~5900.
Old Dec 14, 2004 | 03:26 PM
Myxtreme1's Avatar
Re: Lifters?
No stock heads. I'll be using lloyds and I'm contimplating selling my 227 cam.
Old Dec 14, 2004 | 03:27 PM
dmoor88's Avatar
Re: Lifters?
then definitely go with some comp r's
Old Dec 16, 2004 | 08:08 AM
Myxtreme1's Avatar
Re: Lifters?
Has anyone reused the stock ones with ill-effects?
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
