Lifters?
Lifters?
So what lifters are everyone using? I was looking at the stock ones from gm parts direct, but if the prices are the same then I will probably call Combination. My cam is the 227/233.
Re: Lifters?
Im using Comp R's with the same cam. Im using Crane springs that have a very high seat pressure and was afraid that the stock lifters wouldnt cut it. If you have the funds, Comp R's are just one less thing to worry about but it not, stock replacements should work fine.
Re: Lifters?
if youll be running your RPM's above ~6k, id go with the Comp R's. if youre keeping your stock heads then you may be all right going with stock replacement lifters, since yo uwouldnt run RPM's above ~5900.
