lifter install
Old Nov 8, 2008 | 03:38 AM
scottnorton's Avatar
lifter install
okay so i got this motor off of a friend broke down..and im starting to put it back togeather an its full roller but the more im reading im seeing you have to get the roller lifter install kit is this true... i mean you cant just put the roller lifters in an then the push rods and rockers and so on is there something im missing?
Old Nov 8, 2008 | 05:24 AM
MichiganSkip's Avatar
If the lifters have "tie-bars" then just put them in the holes. If your engine is an LT1 then you will need the "dogbones" and "spyder" to keep them from spinning in the holes.Take somepictures of what you have and post them.
Old Nov 8, 2008 | 02:27 PM
i dont have a camara but im not sure if there stock rollers in the lt1 i got it dissasembled buit its got brackets that go on the lifters then like a retainer that goes on too? sorry about the confuson any help would be great thanks.
Old Nov 8, 2008 | 02:35 PM
LaredoZ28's Avatar
put the lifters in with the lil oil hole either facing the front or the back on both sides then there should b eight lil figure 8 looking things you put on top of those to hold them in. then there is a sheet of metal that has 8 legs that hold the figure 8's down and 3 little bolts hold the sheet metal on.
Old Nov 8, 2008 | 03:32 PM
MachinistOne's Avatar
Can you give me that in layman's terms? A little too technical for me
Don't take that the wrong way lol.
Old Nov 8, 2008 | 03:41 PM
okay thanks for the info
Old Nov 8, 2008 | 05:10 PM
Look at the cam how to's on my Tech Page. It shows pics of all the stuff you are talking about.
Old Nov 8, 2008 | 06:12 PM
LaredoZ28's Avatar
I've run in to many ppl that dont understand the Mechanical terms so I try and put it as simple as I can so that ppl can understand. Sorry if I didnt make it too understandable.
Old Nov 8, 2008 | 06:49 PM
I don't doubt that you know what you're talking about, it's just the wording made me crack up.
Old Nov 8, 2008 | 06:52 PM
LaredoZ28's Avatar
I understand. I'm used to everyone telling me to put it in terms that they can understand. Next time i'll be more technical.
Old Nov 8, 2008 | 11:51 PM
for some reason it wont let me click on it an i have no idea how to get to it.
Old Nov 9, 2008 | 09:08 AM
Must be something your doing. The links are the same as they have been for years.
http://shbox.com/ci/cam_removal.html
http://shbox.com/ci/cam_install.html
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Mar 5, 2015 07:05 AM
