Lifter concern
Old Oct 19, 2008 | 06:39 PM
Green96Z's Avatar
Lifter concern
So I just finished setting up the valvetrain for my LE2 swap, and I noticed the #1 exhaust poly lock had very little resistance when setting my preload, as opposed to the others. There is no slack in the pushrod, but it felt like the lifter was quickly bleeding down or something.
Could this possibly be a bad lifter? I was having no valvetrain issues before, and I'm reusing my stock 80k lifters (nothing strange upon inspection). It is the only lifter that felt like that.
(Valvetrain parts: Stock used GM lifters, Trickflow 7.150" chromemoly pushrods, ARP 7/16" studs, ARP poly locks, Comp Pro Mag 1.6 NSA RRs, using Shoebox's Method #3 for setting lash - http://shbox.com/1/4th_gen_tech2.html#adjust_valves)
Old Oct 19, 2008 | 07:02 PM
Stl94LT1's Avatar
That is normal, it will pump up when the oil pressure rises.
Old Oct 19, 2008 | 08:20 PM
Green96Z's Avatar
Good to hear, thanks!
9t4lt4z28
Oct 2, 2015 10:28 AM
pepon214tx
Sep 20, 2015 04:48 PM
Z Power
Sep 19, 2015 11:19 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
