Lifter?
Old Apr 9, 2007 | 11:43 PM
henryz28's Avatar
Lifter?
Hay guys I just did a lt4 hotcam swap on my 1996 z28 and now I hear a ticking sound at Idal.Befor the swap I would hear ticking when I was going down the freeway and gave it gas; over my loudmouth so it had to be loud.But I couldent hear it at idal.Now after the new timing chain lt4 hot cam and springs I can hear a ticking sound at idal.I adjusted the rockers three times; thinking it was them but the ticking never got better.Now I think the new springs and cam are causing the old weak lifters to bleed down causing the ticking sound.What do you guys think.
Old Apr 10, 2007 | 12:55 AM
henryz28's Avatar
What lifters should I buy?
Old Apr 10, 2007 | 01:13 AM
henryz28's Avatar
will the ls1's from gmpartsdirect work part #12499225?
Old Apr 10, 2007 | 01:12 PM
henryz28's Avatar
come on guys help me out hear.
Old Apr 10, 2007 | 01:14 PM
2000GTP's Avatar
You could just get a stock replacement set, they will be more then adequate for a Hotcam set. Also, the Comp 850-16s are another stock spec replacement set option.
Old Apr 10, 2007 | 01:21 PM
Z95m6's Avatar
You could just help yourself out and do a search instead of TTT your post several times within a few hours.
Old Apr 10, 2007 | 01:25 PM
henryz28's Avatar
are the 850-16s from comp the ones every one is saying not to get because they fail?
Old Apr 10, 2007 | 01:26 PM
2000GTP's Avatar
No, that is the Comp Rs. There is a big sticky addressing it at the top of this forum page.
Old Apr 10, 2007 | 01:30 PM
Z95m6's Avatar
Once again search, search, search. You can buy better GM racing lifters for less money than the OEM replacements.
Old Apr 10, 2007 | 01:33 PM
henryz28's Avatar
ya I know about the gm lifters I just cant find the part number for them.
Old Apr 10, 2007 | 01:48 PM
henryz28's Avatar
Do you guys have the part number for the GM racing lifters.
Old Apr 10, 2007 | 01:51 PM
henryz28's Avatar
are they the 12499225's?
Old Apr 10, 2007 | 01:52 PM
WS Sick's Avatar
Do a search on caddillac lifters and see what ya get.
Old Apr 10, 2007 | 02:00 PM
Colin91Z's Avatar
Good call
Old Apr 10, 2007 | 02:07 PM
henryz28's Avatar
I am going to get the 88958689's from gm.thanks
