life span of a lt1
Old Feb 7, 2006 | 09:46 PM
tastyZL1's Avatar
life span of a lt1
does anyone know the average life span on a LT1 like what mileage untill she dies?
Old Feb 7, 2006 | 10:18 PM
pHEnomIC's Avatar
Re: life span of a lt1
200,000+.
Old Feb 7, 2006 | 10:26 PM
yzblue125's Avatar
Under normal coditions these engines last easily 200k with routine maintinence.
Old Feb 7, 2006 | 11:22 PM
HardcoreRM125's Avatar
Until you cam them, then you have a 50% chance of getting <5,000 more miles before you spin a bearing
They are very dependable motors. Cop cars with them regularly are seeing 150K plus
Old Feb 7, 2006 | 11:49 PM
RayRay21's Avatar
Bad experience I take it?
Old Feb 7, 2006 | 11:50 PM
neil350's Avatar
Use to not be that way, it use to be extremley rare for some one to spin a bearing after a cam swap. The good majority how ever dont break
Old Feb 8, 2006 | 12:04 AM
revtime's Avatar
160k so far and it just keeps getting faster, of course I keep adding speed parts.
I am currently working on a low mount alternator setup and installing a new manifold plumbed for direct port nitrous.
She may not last much longer after that.
I have alot of bolt ons, suspension, and a TH400 is going in soon but the LT1 is completely stock internally and I have bounced it off the 6250 rev limit too many times to count.
Thats the main reason I have not built a monster motor........the stock one just won,t die.
Old Feb 8, 2006 | 12:30 PM
RayRay21 : No, not yet. It just seems like everyone that starts a thread about how their putting a cam in next week, gets on here 2 months later saying that they have no oil pressure at idle and theres this strang ticking noise from the bottom end ...
I really dont think its so much that they are notorious for spinning a bearing, its probably more that half the poeple camming these cars have 100K+ miles, and they were sloppy with the install or something.
Old Feb 8, 2006 | 12:32 PM
Matts1994Z28's Avatar
This is making me nervous about my cam swap!! but then again i do have a fresh 355.
Old Feb 8, 2006 | 04:55 PM
pHEnomIC's Avatar
I think this is true. The cam has to be in there perfect. Any misalignment can destory stuff quick. Do it right and you won't have any trouble, (I would expect a little extra wear due to more hp and you will be driving it harder) but other than that, should be fine.
Old Feb 8, 2006 | 05:04 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Mine lasted 80k then I busted a main cap....
Old Feb 8, 2006 | 05:08 PM
amean94ta's Avatar
how?
Old Feb 8, 2006 | 05:18 PM
I have no idea... Everybody was shocked. If I didn't have bad luck I would have no luck at all... But it gave me an excuse to rebuild her so it was ok.
Old Feb 8, 2006 | 05:21 PM
amean94ta's Avatar
must been a week block cause i have seen 450+ hp and a 300 shot dumped and it just spun the bearings no breakage
Old Feb 8, 2006 | 05:23 PM
2000GTP's Avatar
450+ hp and a 300 shot! Were they looking for an excuse to rebuild the motor?
