Leaking water pump drive shaft seal
Old Oct 5, 2010 | 12:50 AM
Colin's Avatar
Hey guys,
I think I've found my problem but help me out anyway. Is this seal damaged? It's new but I think I made a mistake installing it. It looks like it's been rolled inside out?
The '93 LT1 in my Vega has been run maybe 20 minutes. It's leaking oil like a pig. Oddly, it only begins leaking after the engine has been warmed up about 5 minutes. But, when it leaks it's bad. Within 10 minutes about 2'x2' on the floor is covered in oil. It's done a handy job of oiling up my previously clean install.
Anyway, I bought a new timing cover set this evening. I'm going to follow the advice of this thread: http://www.impalasuperstore.com/nais...TOPIC_ID=30984
I've already made the marker and am ready to install the seal. Is this seal the problem? Here are pics. Thanks.
Old Oct 5, 2010 | 09:55 AM
RUDEDOG's Avatar
That seal is damaged. Use the method in your link with cover installed and it won't leak.
Old Oct 5, 2010 | 12:23 PM
Badly mangled. When like that, they leak terribly.
Old Oct 5, 2010 | 03:02 PM
Colin's Avatar
shoebox,
Oh yeah, it was leaking. As in spraying. Going into the garage after I put my boys down for a nap to fix the seal.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
