leaking injectors!!!
Old Mar 10, 2004 | 11:36 AM
TUFF LT1's Avatar
OK I've been trying to figure out this stumble for several days now and today I came across something. I put a fuel pressure guage on the shrader valve. 30 min later the pressure had dropped from 42 down to 26! So I unbolted the fuel rail and 2 of the new 30# sov's that I installed were really wet. I turned the key to bring the pressure back up and the same thing happened. When I wiggled the injectors a little bit, fuel came out where the injector meets the fuel rail. That didn't happen when I wiggled the other injectors. Are they just not seating right or what? Should I install the old injectors. Thanks!
Old Mar 10, 2004 | 12:13 PM
Fastbird93's Avatar
I'd pull the leaking ones and replace the o-ring at the top of the injector. Problem solved.
Old Mar 10, 2004 | 12:44 PM
TUFF LT1's Avatar
Yea, that sounds like a good idea. I'm going right now to have them checked. Then I'll replace the o ring. Thanks for the reply. I've been reading lots of your old posts about the problem you were having. Gave me some good ideas where to look for the problem. Thanks
CaptainObviousI
29
Apr 29, 2021 10:35 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
NewsBot
May 15, 2015 09:30 AM
Alex Barnes
Jan 24, 2015 10:21 PM
